Question about Kenmore Elite HE3 Steam 8674 Dryer
I have Kenmore Elite HE3 Steam dryer 110.86742700 and it gets very hot
I have Kenmore Elite HE3 Steam dryer 110.86742700 and it gets so hot that you can hardly touch the clothes. I cleaned out the lint area, blower wheel and exhaust pipe and it still does it. I have ordered a new thrmal fuse and high limit thermostat in hopes this will help. Any ideas?
janinedave37
  • 16 Answers
SOURCE: Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Posted on Dec 13, 2008
  • 163 Answers
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
  • 17 Answers
SOURCE: My Kenmore Elite HE3 Dryer is not drying.
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Posted on Oct 06, 2009
How do I repair my dryer?
Hi Is two sample resolution:
1 the out taken pipe is clog
2 the limit cycle sensor is broken
Clean pipe disconnect from dryer, open back dryer cover exchange the sensor.
Oct 15, 2014 | Kenmore Elite HE3 Steam 8676 Dryer
I HAVE A HE3 DRYER HAD TO REPLACE THE THERMAL FUSE AND THE THERMISTOR, DRYER STARTED FINE DRYED ONE LOAD AND BACK TO NOT STARTING THE CLOTHES SEEMED HOT WHAT WOULD CAUSE THESE TWO FUSES TO GO. THE AIR WAY...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 27, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite dryer he3 dryer taking long time to dry
disconnect vent tube run dryer, as the vent is restricted. Good Luck Tim
Mar 13, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite he3 gives me the pf signal and turns off ? what may the issue be?
this is regeristering a power failure,you will need to check the main power supply.there is also a chance that the main control board may be faulty you will need to check all the wiring to the unit.
Feb 02, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore he3: model 110.8708, breaker trips, one side of the 220 line gets hot, and is vibrating while dryer is running.
This may not be tour only but I would inspect the junction block on back of unit where power cord is wired on .sometimes these terminals work loose and start arcing melting the junction then causing a short. UNPLUG UNIT BEFORE INSPECTING. you will have to remove a small inspection cover to see this block, Hope this gets you in the right direction
Aug 13, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 19, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
