Question about Irons
Sunbeam Monitor Electronic Iron 12001
Cord replacement for model # 12001 service # 12 COBL
  • 158 Answers
SOURCE: sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Posted on Jun 18, 2009
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
heatman101
  • 43501 Answers
SOURCE: Model #4214 iron doesn't work properly
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
SOURCE: Sunbeam Steam & Dry Iron Model # 4214
This is an old model, dont think you will be able to find it new. Try ebay or maybe craigslist. Ebay would be your best bet though.
Posted on Jul 23, 2010
baraquielnar
  • 247 Answers
SOURCE: My wife has a Sunbeam iron handed down from her
try to open the terminal box then loosen the screw for line 1 and then the line 2 if you replace the cord see to ti that you wire installed is the same size on old wire.to avoid over loading.
Posted on Feb 25, 2011
Sunbeam iron 5900 2400 watt not become hot. Now what can I do?
opps sr 5900 2400 watt have mixed consumer confidence
http://www.productreview.com.au/p/sunbeam-ultura-sr5900.html
if the dial or iron wont heat up at all
most sunbeam irons have 12 month warranty
if less than 12 months old and you have the reciept
take it back for refund or exchange
if out of warranty toss in the bin...... buy a new iron
Sep 20, 2016 | Sunbeam Irons
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
How to replace power cord on a sunbeam 4214 iron
www.laundry.manualsonline.com has free manual
Jun 09, 2014 | Sunbeam Irons
My wife has a Sunbeam iron handed down from her Grandmother so it is possibly fifty years or more old. It is a model A-4. The iron works well. I just want to replace the cord. How do I take it apart? I am...
Feb 25, 2011 | Sunbeam Irons
The electrical cord seems to have come loose near the iron itself causing the iron to shut off. is this a known problem & how do you fix it?
This has been happening since the first cord was attached to the first electric iron. The cord takes a beating. You will have to disassemble the handle and fix it ... or get a replacement.
Oct 06, 2010 | Sunbeam 6062 Iron with Auto Shutoff
Sunbeam iron won't power up.
Jun 17, 2009 | Sunbeam Irons
Sunbeam Electric Blanket Model 972 A5 Type 692 (or 592) with temperature control 1 to 9 with 75 mins and 12 hrs and off control positions. The light blinks red and the blanket won't heat up. Please...
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
Apr 08, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
heatman101
Jan 16, 2009 | Sunbeam 4214 Iron
Electric cord don't retract on iron model 4219.
I've contact Sunbeam and they're sending me a new iron.
Aug 18, 2008 | Sunbeam 4214 Iron
Open Iron
on most common IRONS , theres a screw located on the back where the main cord is , underneath it , AJ
May 15, 2008 | Sunbeam Classic 3957 Iron
Irons Logo
81 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
