Question about Kenmore Oasis HE 27062 Top Load Washer
Oasis washer I have had repair come out three time they finally found there was coins in behind drum well give me the old washer back i do check pocket but sometimes forget now the noise is back and i cant aford for them to come get a dime out so i need to know how to open the washer to do it my self i hate this washer!
  • 625 Answers
Remove the agitator, then remove the flat steel nut near the bottom. the tub should come right out. you'll need to get a new seal for the tub.
Posted on Aug 23, 2007
My washer is making a card stuck in bicycle spoke sound during rinse/spin cycle
Something has probably got behind the drum. Usual suspects are broken underwires from bras and hair clips or pins.
Spin it by hand when empty, both ways and see if you can figure out where it is at. Check the filter and the flexible rubber hoses from the drum drain point to the filter and the filter to the pump. Give those hoses a squeeze and see if you can feel anything in them. I have found bits of underwire, coins and small metal items. They are removable with a bit of effort, but be prepared for water spillage. Take a photo before you remove anything so you can see how it all fits back together.
Feb 03, 2016 | Maytag Centennial MVWC300VW 3.2 Cu. Ft....
Coins
It might well be a coin! Coins and other items that fall from clothes pockets into the drum stay in the drum. They are too large to pass through the small drainage holes in the drum. But my granddaughter found a way! She opened the washing powder dispenser at the top of the machine and dropped three coins (that we know about) into the drawer and closed it. The water fill cycle then somehow swept the coins down into the drum. To get them out I had to dismantle the machine and remove the pump outlet assembly and poke a stiff wire into the drum and drag the coins out. The machine is a completely different make to your but I would assume a similar method would work. good luck
Dec 31, 2013 | General Electric GTWS8655DMC GER 5.0 DOE...
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
Dec 23, 2017 | Maytag LAT3600A Top Load Washer
My Kenmore Oasis HE is about 4-5 years old. Withing the last 6 months or so, it has started faulting to UL(uneven load) in the final spin cycle every load. It doesn't matter if I am only washing 1...
Sears has a recall for the Kenmore Oasis washer. I have the exact same problem. Call Recall Line @ 1-800-659-7026 with Model number and serial number. The part is a control board that works with the spin cycle.
Feb 25, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore oasis top load washer and when the water is pumping out I hear a loud rattling sound like a coin is stuck or something. I have already taken the inner basket out and found nothing but an...
i would say its definitly a coin have you pulled the pump appart to expose the blades? this is were i would expect to find it
ps well done on taking out the barrel thats a hard job if not trained.
best of luck
Dec 02, 2010 | Washing Machines
My washer started leaking, we checked all
Three times we have had problems with our drain pump and coins making it through. Once the coins made a hole in the intake hose. The last two times the coins went through the pump and the impact cracked the pump housing causing a flood in our laundry room. The sevrvice man advised there was no solution to the coin problem other than making sure you check your pockets thoroughly.
Mar 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have coins under my tub in my kenmore elite oasis. How do I remove the tub to get a the coins that are rattling every time the pump runs?
DO NOT attempt to turn this washer upside down! The wash tub is suspended by suspension springs and it will dislodge the wash tub from its mounts. The washer also weighs about 200 lbs. Not a bright suggestion.
In addition, if this is an OASIS, no special tools are required to remove the wash tub. It usually involves removing the center cap from the wash plate and loosen the bolt underneath with a socket. You will need to remove the wash tub ring in order to get the wash tub out, however. This is the pastic ring around the top of the wash tub. It simply snaps in place and can be removed by popping the retaining taps free with a screwdriver.
If you hear a rattling noise, I would recommend you check the drain pump first as "titelines" suggested. It is common for items to get lodged in the piump impeller and make noise. Keep in mind...there are TWO pumps on an Oasis. One is a recirc pump. Check them both. If anything has been left in the pump for any significant period of time, it can damage them.
You will need to access them both with the rear panel removed and the wash tilted up so you can access the mounting bolts and screws from underneath. I would STRONGLY recommend you drain all residual water from the wash tub prior to disconnecting any drain hoses. If you own a wet/dry shop vac, this can be accomplished by removing the drain hose from the standpipe and pulling a vacuum on it. This will minimize any mess you may have to clean up later.
If your model number differs from the one you posted this question under, please post back with your correct information. I hope this helps you.
Nov 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Hole in pump caused by coin -- causing flooding
There is no screen! I bet it was a dime that was caught in the pump. It has happened to me several times to the point where we double check all pockets when loading washer. Coins larger than a dime stay in drum or in lower basket. Poor design! I now leave the back of washer loosened and have mastered pulling hose off the PLASTIC pump housing and reaching in to pull out the coin.
Apr 06, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
