Question about Sony Dvcam DCR-HC15E Mini DV Digital Camcorder
DCR-HC15E Condensation error - cannot clear error and insert tape
My son tells me he was using the camera while on a recent holiday in a coastal environment when the camera gave a message to eject the tape. He did this and since then he/we have been unable to re-insert a tape and the camera reports the condensation error.
It has been over a week now with no success and we have tried all the suggestions to try and clear the error, including the one from wiz 'eagle338' on this site, but the error still exists.
I work in the technical field myself but not with video equipment so do have some technical experience.
Any tips on anything else to try or check for this error would be greatly appreciated. Could the moisture sensor itself be faulty or dirty? Where is the sensor located so I can check and/or clean it?
Thanks in anticipation for your help.....
cheetdj (Daryl)
  • 2 more comments
  • cheetdj Jan 13, 2009
    It appears I've been trying to fix the wrong problem with my camcorder as it appears the problem is not condensation error at all.
    While searching the internet last night I located the service manual which gave me a list of the error codes. The error the camera is reporting is C:31:40 which translates to 'FG fault when starting drum'. The corrective action stated is 'load tape again, and perform operation from the beginning', which does not work for me as the error is reported whenever I attempt to insert a tape.
    Any help with this problem will be greatly appreciated.....
    cheetdj (Daryl)
    I am able to remove the tape OK. The problem is I am unable to insert the tape. The camera tape mechanism starts to load the cassette but it only travels a short distance then stops, beeps and reports the error I stated in my previous post which is C:31:40. This translates to 'FG fault when starting drum' from the list of error codes provided in the service manual. I obtained a copy of the manual last night.
    Thanks for trying to help so far.....
    cheetdj (Daryl)
    Hi ginko,
    Thanks for trying to fix the problem with my camcorder. Whilst your advice did not specifically fix the problem, I think you were right with your thought that there may be a problem with the drive mechanism for the drum.
    I contacted a Sony authorised repairer today about the problem and they advised to try and remove all power from the unit (as you did) for an hour and power it up again using the AC adaptor. While it was powered down, I probed around the drum with a cotton bud and it did appear to be stuck. It did seem to free up again while probing and when power was re-applied (via the AC adaptor), the tape was accepted but it then reported a different 'drum error'. A few more trys however seems to have fixed the problem and all is working again - for now anyway.
    Thanks for trying anyway and your offer of help is appreciated. I guess we would have got there in the end.
    Regards,
    cheetdj (Daryl)
  • cheetdj Jan 14, 2009
    Hi ginko,
    Regards,
    cheetdj (Daryl)
  • 81 Answers
Have you tried to spin the drum with a Qtip or the eraser on a pencil? If you use the pencil method be gentle. It says if there was condensation on the drum the tape would have stuck to it. Maybe something stuck to it? Or have you pushed the reset button to clear memory? Do a reset with the camera on after spinning the head to check it for movement. Hope this helped
Posted on Jan 13, 2009
  • 163 Answers
Hi!!! Have you try removing the battery from the unit..Buckwheat also said, good luck..DCR-HC15E Condensation error - cannot clear error  - cc8b5fa.jpg
    Sergeant:
  • 221 Answers
 Hit your camera several times with a flat hand (bottom, tape side). Its strange but the problem will be solved. On internet I found maybe 10 or 15 other people who did the same. For all of them this worked fine. try several times as once it will start working it will not show the error again.
thanks.
    Sergeant:
    Novelist:
  • 326 Answers
It indicates that the allignment of the internal parts has been moved from its orignal position so this problem.just tap the sides of the camera for couple of minutes and try checking it again.
  • Sony Master
  • 19,396 Answers
To start do all removing battery and removing tape procedure.
try inserting a different tape and rewinding the whole tape, or forwarding it to the end.
If it still does not start with any tape (try different ones) then there is a fault on the gears that move the drum, but that is rare.
Ensure well that tape is getting well in position inside, and that door is closing well, and that is not the tape that you are using that is usually the problem.
  • 818 Answers
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Sony DVC-TVR20 won't accept tapes
most of the errors get solved with a hard reset
did you try it?
leave the unit plugged off from power for few hours
Jul 17, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Tip
Hi Eagle338, Thanks for your tip for the condensation error on the DCR-HC15E. I...
When this error occurs, just switch on the camera and leave it like that for about one hour.. it will clear by itself..
on Jan 11, 2009 | Canon MV800i Mini DV Digital Camcorder
C:31:23 DCR-HC15E
Tape mechanism of DCR-HC15E camcorder is worn out, contact nearest Sony service center for mechanism replacement.
Mar 27, 2009 | Sony Dvcam DCR-HC15E Mini DV Digital...
Promblem with sony
I have a sony vaio cr590 with iLink port and DV Camcorder sony HC15E and I cant recieve any signal by Click to disc Software, Please Help me.
Dec 30, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
DONT HAVE A DRIVER cd
here are the links
http://www.nodevice.com/driver/DCR-HC15E/get39682.html
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR-HC15E_Windows_XP_Driver.html
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Sony-DCR-HC15E-Twain-Patch.shtml
Dec 08, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Handycam Sony DCR-HC15E does not play at win. vista
check update for DCR-HC15E windows vista system on floowing website.
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?l=en&m=DCR-HC15E
Hope your problem will be resolve.
May 28, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
Sony TRV460 error code C31:22
Manual says probably condensation - see page 121
Dec 11, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
SONY DCR-HC15E RECORDING PROBLEM
Please, practice another sport...like the chess, maybe this dont fuck your handycam.
Apr 14, 2007 | Sony Dvcam DCR-HC15E Mini DV Digital...
Sony Dvcam DCR-HC15E Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
