Question about Plumbing
Franke ff-380 leaking where pull-out hose attaches to faucet head. How do I repair it?
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
bearsfan7538
  • 119 Answers
SOURCE: What tool and what size of this tool is needed to
You need an allen wrench set
Posted on Nov 28, 2009
  • 129 Answers
SOURCE: How do you remove aerator from franke pullout
A small crescent wrench should do just fine. Just be careful not to cross thread when putting it back on.
Posted on Jan 31, 2010
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
  • 10865 Answers
SOURCE: We have a 1986 single-handle
Hello feleppa... Most faucets can be repaired. That said, if you can not figure out how to disassemble it you could consider removing the entire faucet and taking it to the hardware store. Most hardware stores are expert at repairing faucets, if the parts are still available.
That said, this faucet is 26 years old so getting parts may be a challenge. My advice to customers in this situation is to put the repair money toward a replacement, unless the faucet has sentimental value.
Joe
Thanks for choosing Fixya!
Posted on Jan 16, 2011
I also have a Franke 200 series faucet and it's leaking where pullout spray attaches to supply tube after replacing washer....is it possible for sprayer hose to leak...its silver not just a nylon hose
Although I am unfamiliar with the name "Franke", I am more than familiar with this problem.
I have had it too many times to count.
I have discovered it takes an assortment of black rubber/plastic washers to fix this.
I even have them in my tool box for this very problem.
Not enough washers will cause a leak, too many and the hose will not ***** on.
I have had to experiment with different washers to get the fix.
God bless your efforts.
Apr 04, 2016 | Franke Plumbing
How do I remove a seized handle on my FF-600 Franke faucet.
Refer to the link for drawing of the FF.660.
It looks like the Cover 45019 attaches to the faucet body I would brush some vinegar on/in any openings around this part for several minutes then heat the cover by pouring hot water over it after that use a Strap Wrench to try to turn the cover anti clockwise. It may take a few tries to dislodge the corrosion before it will release. Repeat with Valve 3699 and a wrench.
http://www.guillens.com/faucetparts/franke/images/FF600.jpg
Nov 10, 2013 | Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
Franke pull out spray broken
check to see if the weight on the hose got shifted too far back (if it was loose it could slide along the hose).
Feb 08, 2012 | Franke FF-303 Kitchen Faucet with...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
Plumbing Logo
64 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
