Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Laptop boots to a black screen Dell Inspiron 10 min to boot up
    Novelist:
  • 250 Answers
Do the following tasks:
Reinstall your video driver
Check for registry issues
Start the computer in safe mode and run System Restore
Also Removing the graphics driver in safe mode might work for you. Just remove it via Device manager.
If black screen still appears then use a system utility software like ReginOut.
Hope it works for you.
Posted on Dec 13, 2012
jell587
  • 447 Answers
SOURCE: Dell Inspiron 531s Windows Vista
If you are given the option to go into the setup (F2) try to disable the floppy disk drive or move the hard drive up in the boot order.
Posted on Feb 21, 2009
sodeep
  • 3267 Answers
SOURCE: Will not boot
Insert your bootable OS software disc in the CD/DVD drive and boot from the ROM. Run checkdisk and then try to repair the OS from the original OS disc, it should give you a chance to start the PC after that continue as per instructions on the screen...................sodeep
Posted on May 11, 2009
  • 62 Answers
SOURCE: How do I get into safe mode on a Dell Inspiron
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
Posted on Oct 27, 2009
  • 3940 Answers
SOURCE: dell inspiron 530s won't boot up and gives me 4
4 Beeps indicates a RAM memory failure. Disconnect power, press and hold the power button to release all power from the motherboard, then re-seat the Memory.
If error doesn't go away, try modules one at a time to find the bad one
Posted on Dec 27, 2009
FixinFax
  • 3085 Answers
SOURCE: boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Posted on Jan 06, 2010
Dell Inspiron One 19 Black screen after dell logo boot up
Sounds like you have a video driver issue. See if you can boot from your "Dell Resource" CD or any other bootable CD disk. Power on the computer and tap the F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" into the CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If the computer boots from the CD drive then you Operating System Software is the problem.
Mar 19, 2013 | Dell Inspiron One 19 All-in-One Desktop PC...
Dear sir i have a dell inspiron notebook without cd/dvd RW when i started it "boot manager missing" what to do
restart the laptop and keep pressing F2 when the DELL splash screen comes up before windows loads. Inder boot settings make sure The hardrive is selected as the primary boot drive.
May 11, 2011 | Dell Inspiron Mini 10 Notebook
Dell Inspiron 2200 boots up but 1-2 min in the screen goes to a faint black. You can still see the desktop and everything just very faintly. Like a fain transparent black.
Check with your Power Plan or screen saver option, you might have it adjusted to super energy saving to make your battery last longer and have the screen dim, or backlight shut off since you mention it take 1-2 min to boot up ...see if that might help.... If that didn't do the job, I suspect your backlit lighting might be going bad. Let me know what Operating system you are using too. So like I said, check your screen save and if it is set to dim, or shurt off withing a minute or two... set it to something longer to see if that works.
Jan 15, 2011 | Dell Inspiron 2200 Notebook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
After startup about 5 min and screen turned to black. If you restarts it and the same thing happens again.
5 mins!!???
My Dell Inspiron 2200 boots up in 22 secs and its got win 7 on it with 512MB of RAM!!!
Right, this often occors when there is a USB or DVD drive in the slot.
Dec 31, 2009 | Dell Inspiron 6000 Notebook
My dell inspiron b130 boots up but monitor is black
After your laptop boots up into windows, hold down the Fn key and as your doing that press the F8 button that should switch the output from the vga connetor to the LCD screen on the laptop.
If you still don't get video then you'll have to reseat the LCD cable from the back of the LCD screen to where it connects to the motheboard.
If you still don't get video then its either going to be a bad LCD or a bad motherboard.
Aug 09, 2009 | Dell Inspiron B130 Notebook
I have a Dell 600m that boots up and then screen
try turning the computer off for 20 min.or 40 min. then turn it back on
Jun 16, 2009 | Dell InspironTM 600m Notebook
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
97 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
