Question about Maytag Dryers
The dryer runs but does not heat.
I've tested all the thermostats. Bought a new heating element even though the old one tested out, as a final test. I am getting 120V at both terminals of the heating element when the dryer is turned on, yet I'm not getting any heat. Any solutions?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check the thermostats again. One is bad.
Posted on Dec 02, 2012
  • rdrobertson1 Dec 02, 2012
    i bypassed all the thermostats by connecting the wires with electrical tape. still not heating. have you experienced this before ?
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
  • 163 Answers
SOURCE: frigidaire front load elecrtric dryer runs but no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE: Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Posted on Jan 18, 2009
  • 1122 Answers
SOURCE: Kenmore Dryer 60982 Runs but No Heat
you can check them all with an ohms meter but i think it is the thermal fuse at the top of the heater box that is bad-mike
Posted on Jun 04, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
Dryer heating element comes on sometimes and then shuts off.
Start by checking all the thermostats for continuity.
Nov 05, 2012 | Dryers
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Hoover VHW654D-80 not heating
    see the causes, and proceed. God bless you
    Heating Element
    hermal Fuse
    Thermostat
    Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Sep 22, 2012 | Washing Machines
    Brand new dryer wont heat
    depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
    Feb 17, 2012 | Roper Dryers
    Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
    Runs but will not heat
    1.loose wiring----check terminals & wiring
    2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
    3.defective timer---replace
    4.open heat element---replace heat element
    5..defective operating thermostat---test thermostat, replace if defective
    6.fan or it's pulley loose on shaft---tighten set screw
    7.incorrect heat or timer settings---reset timer
    8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
    9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
    Sep 25, 2011 | Dryers
    Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101
    Aug 24, 2011 | Dryers
    Hi I have an Electra tumble dryer which dont heat up ! I've changed the heater element which hasn't cured it so I taped the full heat thermostat wires together but stil no heat ?? Thanx
    heatman101
    Jul 18, 2011 | Electrolux Dryers
    I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
    Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
    Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
    Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
    If I remember correctly, this model has a switch on the motor which activates both legs
    of the 220 to allow the heating element to come on. There is a wiring diagram under the
    lid of the dryer and should show this. Hope this helps.
    Jun 21, 2011 | Dryers
    I switched my Kithen Aid Electric dryer [KEYE664W] from mediun to high heat AND THE HEAT STOPPED! Now all temps have know heat. Blower works.
    You may have had a short circuit between the heat selector switch and the element/thermostat!! Have a technician test the heat switch, and the element and thermostat.
    Dec 14, 2009 | Amana NDE2330AY Electric Dryer
    Dryers Logo
    75 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
