I have problem 4r strting up my computer i dont know why? when i try to start up it gives some choices like stert up normally and safe mode and something like that and when i choice one of them it try to start and restart again so if u can help me plzz
    Guru:
  • 829 Answers
Hi What start up problem . may be u need to check the RAM or SMPS.
Posted on Jan 11, 2009
HOW can desktop be rebooted& I don't know which reboot option to choice
There are a few reboot options. The first reboot is to start a pc normally. The second is Safe mode. Another is Safe mode with Networking. and another is Safe mode with command prompt. Use Safe Mode to do minor adjustments or repairs, or virus scans while connected with the Internet with Networking option. DO not use Safe mode with command prompt unless you know what you are doing!
Apr 10, 2017 | Option Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
My Toshiba Satelite Laptop pre-loaded with Windows Vista Home premium is not strting in normal mode but it does start in Safe mode with networking. How to make it work?
You can use system restore and restore your computer's settings to a previous date. Please choose a date during which you know that your computer worked fine. This will remove any recently made change that had affected windows Vista in your computer
Mar 17, 2011 | Toshiba Satellite A105 Notebook
Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Display driver crashes & recovers. Sometimes over and over again until computer crashes. Then I have choice of safe mode, normal etc.
restart computer at startup press f8 down for 3 secs / should give u options /go to safe mode hit it follow on sceen till u get to desk top open controll go to uninstall programs open and find the driver u put on should be display and deleat then restart should solve dave if not f8 restart try f11
May 01, 2009 | Computers & Internet
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
PC won't Start windows normally
You can attempt to undo this through the use of System Restore.
I am going to assume you are on Windows XP, So start your computer in safe mode without networking.
Once you are in the desktop you are going to use System Restore. Choose a date in time on your computer before the incident happened.
For more information on the system restore utility go here:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Note : If you have Windows Vista ,read about this utility here:
http://windowshelp.microsoft.com/windows/en-US/help/9f6d755a-74bb-4a7d-a625-d762dd8e79e51033.mspx
Aug 20, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
