Question about Water Heaters
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10 mins before startin the second shower that person will seem to have all the hot water they need without water turning luke warm. Is this a termostate or element problem. The unit has an upper and lower element.
  • Steve Pack
    Steve Pack Jul 24, 2017
    More than likely what is happening is that there is an accumulation of rust and water deposit that formed on the bottom of the water heater tank and this is inhibiting the transfer of heat from the to the water.
    There should be a drain on the bottom of your water heater that you should regularly drain the water from it. This should be done every couple of years to prevent such problems.
    Turn off your water heater temporarily, attach the end of a hose to the bottom drain and run the other end to a floor drain or nearby slop sink. Open the drain valve to help try and flush a lot of that sediment out from the bottom. Don't be alarmed if the water looks rusty or grainy, this is normal wear and tear for a water heater.
    See if this helps and if not then it is probably time for a new water heater.
  • 62 Answers
Sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Posted on Jul 25, 2017
3 Suggested Answers
  • 659 Answers
SOURCE: not enough hot water
Makes you feel good to save some money right? Have a great day!
Posted on Apr 10, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
I am looking for magnesium anode rod for an electric Ruud pacemaker 10 gallon water heater model# PEP 10-1 and serial # 0598304245. Do you know the parts number? Bill
no
try contacting the manufacturer for the part or talk with a plumber supplies shop ( where plumbers get their supplies and parts ) to see if it is available
it will be a sacrificial rod to prevent the tank from corroding out especially around the heating element fittings
Jan 29, 2017 | Water Water Heaters
Richmond 5v40-36f
1) My search does not show that product exists, or existed before the internet.
Maybe that product only exists on fixya.
Or the water heater is older model number from Rheem., aka Richmond, Ruud etc.
Or fixya picked up a model number from a question, and the person asking question did not copy model number correctly from label on side of tank.
It might also be older manufactured home gas water heater.
Feb 07, 2013 | Audiovox Water Heaters
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
How to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Aug 26, 2012 | Water Heaters
My old Ruudglas Pacemaker's pilot light went out.
Well if the hi limit is not out then you need to replace it.One more thing to check is to make sure the flame is touching the thermocouple.You can find parts for most water heater at lowes or home depot,plug hardware stores.You need to make sure you one for millvolts 750volts
Mar 14, 2009 | Water Heaters
Water Heaters Logo
476 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
