Question about Little Giant Home Security
Control panel open/close malfunction w/save-t cover II [remote oper.] plus receiver bar bad
Receiver bar to control box is bad. cut by mower. plus control box had been receiving rain/sprinkler water. THIS IS THE EARLIER MODEL THAT HAS A CARRY REMOTE BOX TO OPERATE THE COVER. FACTORY SEEMS TO BE IN DIS-ORDER. I,M LOOKING FOR T-BAR AND OTHER PARTS. THANK YOU DON L. LYONSAB@AOL.COM
johnson4lake
SOURCE: Remote Control Programming
Go online and search for the owners manual for your TV. It has the common codes for receivers, DVD players, etc. listed in the back with the instructions on how to program the remote.
Posted on May 10, 2008
SOURCE: Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Posted on Nov 14, 2008
  • 6 Answers
SOURCE: how to program onkyo tx-sr606 receiver onto remote control
I think onkyo has not come up with codes for game console yet. Codes that are available are for DVR/VCR, CD, DVD, TV. and Setup Box. I need to get the manufacturer of those components that you have for me to be able to determine which code is appropriete for your components.
Posted on Nov 29, 2008
  • 3197 Answers
SOURCE: My Craftsman 139.53879 remote won't learn the code
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Posted on Jun 29, 2009
  • 1039 Answers
SOURCE: Lock control program after open cover lid of Pioneer PDP434 PG
If you had power this set on with the back off it will not work without closing the switch again and entering serv mode and reactvating . Call pioneer customer serv to get info to reset the unit. Must have pioneer remote to do this reset.
Posted on Aug 29, 2009
Can not open trunk on a pontiac soltice. No clicking sound from remote or switch in glove box fuses are ok
The rear compartment lid release system consists of the following components:
• Body control module (BCM)
• Folding top cover actuator
• GMLAN serial data link
• Keyless entry transmitter
• Rear compartment lid ajar switch
• Rear compartment lid release actuator
• Rear compartment lid release switch
• Remote control door lock receiver (RCDLR)
• Trunk fuses
• Trunk release relay
Rear Compartment Lid Release System Operation
The rear compartment lid can be released by operating the rear compartment lid release switch or pressing the rear compartment lid release button on the keyless entry transmitter. When the rear compartment lid release switch is operated, the rear compartment lid release switch signal circuit to the body control module (BCM) is switched to ground. The BCM receives the rear compartment lid release switch input and applies ground to the trunk release relay control circuit. This energizes the trunk release relay coil, closing the switch side contacts, allowing battery voltage to be applied to the rear compartment lid release actuator and folding top cover actuator, releasing the buttresses and opening the rear compartment lid. Ground for the rear compartment lid release switch is provided at G300. The rear compartment lid ajar switch, rear compartment lid release actuator, and folding top cover actuator are provided ground at G301. The rear compartment lid will not release until the vehicle speed is zero and in park.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B3265 01 : Trunk Relay Output Short to Battery
DTC B3265 06 : Trunk Relay Output Short to Ground or Open
Do you know what a relay is an how it works ? TRUNK release relay located in the underhood fuse / relay box.
VEHICLE RELAYS Operation Diagnosis
Jul 22, 2017 | Pontiac Cars & Trucks
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
Mar 20, 2017 | 2007 Mercury Milan
My 1998 Silhouette back door won't unlock with key or fob
follow the steps and fix it. God bless you
    • 1 Enter the passenger side of the vehicle and look under the dashboard, beneath the glove box and near the floor mat. With the aid of a flashlight, locate a large panel, which is held in place by screws. Unscrew the panel manually or use a screwdriver if the screws are too tight.
    • 2 Locate the fuse panel. The panel houses long rows of fuses mounted to the panel. Consult the vehicle's owner manual to determine which of the fuses controls the automatic doors
    • 3 Remove the fuse that controls the automatic doors with a pair of fuse pliers, or carefully with a pair of regular pliers. Examine the fuse by shining the flashlight close against it. If the metal bar inside the fuse is broken, the fuse has been blown.
    • 4 Replace the blown fuse with a fuse of equal amperage. Push the new fuse in place, confirming it is a snug fit.
    • 5 Test the automatic doors before screwing the fuse panel cover back in place. If the doors close automatically after you manually give them a tug, the problem was the blown fuse. Replace the fuse panel cover under the glove box.
    • 6 Test the automatic doors with your remote control. If they do not open or close, the problem is with the remote. Pop the rear cover off of the remote with a screwdriver and replace the battery.
Oct 18, 2012 | 1998 Oldsmobile Silhouette
I need instruction manual for remote control part number: 5000022000
Remote Wonder Link
http://support.amd.com/us/GPU_TechDocs/remctrl.pdf
Remote Wonder II Link
http://support.amd.com/us/GPU_TechDocs/rw2.pdf
Remote Wonder Plus
http://support.amd.com/us/GPU_TechDocs/remotewonderplus.pdf
Not sure which remote manual you are looking for, so here are all the ones listed on AMD's website. Click the link, then when your pdf reader opens the file, go to "file" then "save as" to save your own copy. Hope this helps.
Happy computing!
Oct 07, 2009 | ATI Remote Wonder Remote Control
Aug 29, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Receiver won't fit Model 52-CS
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
May 15, 2009 | Hampton Bay 13087 70450 Carousel II...
Sears Craftsman 1/2Hp Garage Door Opener - Opens on its own
There are three causes for this problem:
1. a remote is sticking or is getting bumped (if the vacation lock is on and it still has phantom operation remotes are not the issue).
2. the logic board could be going bad (if you have the 315Mhz you have a newer operator so this is probably not your issue)
3. the wires to the wall button have a short. Try disconnecting the wall button wires from the operator. If this stopps the phantom operaton you might solve your issue by running new wires to your wall button.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Home Security Logo
83 people viewed this question
Top Little Giant Home Security Experts
Lawrence Oravetz
Are you a Little Giant Home Security Expert? Answer questions, earn points and help others
