Where can I buy the 5 capacitors for my onykyo TX SR606 reciever and are the 100 microfrad 4 volt
I need to know where to buy the 5 capacitors and are the 100 microfrad 4 volt capacitors
  • 17 Answers
SOURCE: ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Posted on Dec 03, 2008
SOURCE: onkyo tx-sr606 can not get it to work w tv using hdmi cables
try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Posted on Dec 07, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
SOURCE: Reciever turns off
North American models are all set to 6 ohms. You can't switch the setting.
Try reconnecting the speaker wire into the back of the unit. This worked for me.
Posted on Dec 27, 2008
smarthome2
  • 1114 Answers
SOURCE: Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Posted on Jun 11, 2009
Onkyo sr606 service manual
Go to Onkyousa.com, move mouse cursor to support, click on owner's manuals, click on receivers, click view archived receiver models, click TX-SR606 (both"quick setup" and "HTS 7100 for the full manual").
Oct 18, 2012 | Onkyo TX-SR606 Receiver
Can not get picture throug dvd player
You may want to be more specific on what the symptoms are, however I had a problem getting picture though my components ... along with a few other more major issues. I replaced some capacitors on the HDMI board (not as hard as people think). Search "how to fix an onkyo tx-sr606" on youtube. It will show you how I fixed mine.
Dec 25, 2010 | Onkyo TX-SR606 Receiver
Can i hook up to internet
Hello Fixya customer,
Thank you for your question,
There is no LAN connection for the TX-SR606. The available connections include, HDMI, Component, Composite, S-Video, Optical, Coax, and analog audio. The ports that you are referring to may be the HDMI ports.
Thank you for using Fixya.
Apr 29, 2010 | Onkyo TX-SR606 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
I am having HDMI output issues to my HD TV. The issues are intermmitent. I have my HD cable box, BluRay Player both hooked into the reciever via HDMI. The Hdmi output of the reciever feeds my TV. I have...
Have you proven that a straight shot HDMI to the TV from either source solves the problem?
For all we know the TV or it's HDMI cable could be faulty.
Apr 09, 2010 | Onkyo TX-SR606 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Remote control codes
it does not exist for that remote.
Aug 13, 2009 | Onkyo TX-SR606 Receiver
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
Nov 16, 2008 | Onkyo TX-SR606 Receiver
Receivers
If it is me and I am spending that kind of money, it is going to be sick, os here is sick. 7.1 dolby surround and 1080P HDMI, 135W per channel, and right now if you go to FRYS.com, it is normally $500.00 bt for right now it is only $449.00. But if you put this in, be prepared to buy a PS/3 as your next investment (Th best way to get Blu-RaY at an affordable price, plus many other features) and an upconvert DVD layer, which is only about $100.00 or less today. Then you better get ready to hear from your neighbors and the cops, because they are going to think a war has broken out in your place. Enjoy, I play movies that the sound is just so realistic, I hate to leave the house anymore. Also, remember, speaker placement is key, so know the optimal environment for your system and if you need one, I may be able to hook you up with a system room tuning DVD for next to nothing. This will allow you to setup your system and place your speakers optimally for your environment. good Luck.
Onkyo TX-SR606B
7.1 A/V Receiver with HDMI Up-Scalling
Onkyo USA:
FRYS.com #: 5586420
The Progression of Affordable High-Def Home Theater Continues with Full HD Integration and Video Upscaling As part of the second generation of Onkyo high-definition-capable receivers, the TX-SR606 is at the forefront of affordable home theater. The key is to have the most capable version of HDMI. The TX-SR606 provides high-definition video and audio processing for four source components—another first for Onkyo at this level. From Blu-ray Disc players to gaming consoles and cable/satellite boxes, you have everything in the digital realm covered. Apart from 1080p video, the TX-SR606 can upscale all video signals to 1080i, regardless of the connection, for output via HDMI. Onkyo's own RIHD (Remote Interactive over HDMI) also gives you inter-operability with the displays and playback components from other leading brands. And with an expanded version of Audyssey's room correction technology, the TX-SR606 maintains the fullness of surround sound audio quality at low volume levels. The TX-SR606 offers all-round excellence rarely seen at this levelSpecial Features
  • HDMI v1.3a Repeater (4 inputs, 1080P compatible)
  • HDMI Video Upconversion
  • 1080i Upscaling powered by Faroudja DCDi Edge
  • TrueHD, DTS-HD Decoding
Amplifier
  • # Channels 7
  • Power (8ohms 20-20kHz 0.08%) /Ch 90W
  • Power (8ohms 1kHz 0.7%) /Ch 105W
  • Continuous 6ohms Rated
  • High Instantaneous Current Capability 36A
  • Amplifier Frequency Response 5Hz-100kHz
  • S/N Ratio (LINE IN) 106dB
  • All Discrete Circuitry
  • Absolute Ground Plate
  • Optimum Gain Volume
  • Non-Scaling Configuration
  • Bi-amp Capability For Front
Processing
  • DOLBY Decoder DD Plus, TrueHD
  • DTS Decoder DTS-HD Master Audio
  • Direct Mode
  • Music Optimizer
  • Audyssey Dynamic EQ
  • 192K/24 Bit DACs
  • DSP Type / QTY 32 BIT
  • Adjustable Crossover 40/50/60/80/100/120/150/200Hz
  • Independent Crossover
  • AV Sync
  • Accurate Speaker Distance Setting
  • Multi-Band Speaker EQ 5 Band
Connectivity
  • Audio In/Out 7 / 2
  • Digital Audio IN (OPT/COAX) 2 / 2
  • Composite In/Out 5 / 1
  • S-Video In/Out 4 / 1
  • Front-Panel A/V L / R / V
  • Component Video / Bandwidth 2 in / 1 out / 50MHz
  • HDMI In/Out 4 / 1
  • HDMI Version V1.3a Repeater
  • HDMI Bandwidth 1080p
  • HDMI Deep Color Capable (36bit)
  • Analog to HDMI Upconversion
  • 480i to 480p Processing (DCDi Edge)
  • 1080i Upscaling
  • Multi-Channel Input 7.1
  • Surround Pre-Outs SUB
  • Powered Zone2
  • Zone 2 Line Out
  • iPod Ready (DS-A2x, DS-A2, DS-A1)
  • SIRIUS Radio Ready
Integration Access
  • Onkyo-RI System Control
Miscellaneous
  • Pre-Programmed Remote
  • Glossy Black finished Remote
  • Simple Remote to change input & mode
  • Color-Coded Speaker Terminals
  • Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
  • On Screen Display Out
  • Permanent Memory Storage
  • Solid Aluminum Front
  • Warranty 2 YEARS
Oct 13, 2008 | Audio Players & Recorders
23 people viewed this question
 Grubhead
Grubhead
