Question about Kenmore Dryers
Remove top of kenmore dryer 41783042201
The dryer is making a squeaking noise and I cannot get access to the inside of the dryer.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Take a look at this video.
Posted on Dec 02, 2012
  • 146 Answers
SOURCE: Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Posted on Dec 21, 2007
Illeagle
  • 525 Answers
SOURCE: dryer squeak
Your issue is as follows;
"My G. E. dryer make squeaking noise when the drum is turning. However, it only during so, when load with cloths."
Based on the information provided above, I am unable to access my database to provide you with exacting information. You did not provide a valid model number, however, I have provided some common solutions to help guide you in your search.
My Solution is:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Following the link below will provide some information on G.E. dryers.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=784658&PPStack=1
Following the link below shows disassembly procedures for most G.E. models.
http://www.repairclinic.com/0100_20.asp
Rear drum bearing: Most common failure Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 17, 2008
SOURCE: how to stop squeaking noise on dryer
The roller bushings/bearings and the motor need lubricating.
If you want help with how to do this, let me know.
Posted on Apr 30, 2009
  • 46 Answers
SOURCE: squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
Posted on May 25, 2009
Controlfrk
  • 304 Answers
SOURCE: Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Posted on Sep 20, 2009
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
I have a kenmore washer dryer ( stacked ) heavy duty 2 speed motor . The top dryer is SQEEEEAKING so loud it is making me INSANE . I removed the front of the unit so I could see the drum and belt ... then...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 23, 2011 | Kenmore Dryers
My kenmore stackable dryer squeaks really loudly. how to stop this it's making me crazy
heatman101
Asker
Jan 23, 2011 | Kenmore Dryers
When I run any cycle, it is squeaking and making noises. It sounds like the dryer cylinder is loose. Kenmore Elite He5t Gas Dryer
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 31, 2010 | Kenmore Dryers
Makes noise & tore up sweater
heatman101
789df
Nov 30, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Sep 20, 2009 | Kenmore Dryers
Squeeking noise when drying
you have a whirlpool made kenmore dryer , there are 3 moving parts that can be making this noise , the belt tensioner and 2 wheels that the drum rolls on .
to get to these parts you go into the front of the unit. start by removing the 2 screws on the top where the lint screen inserts. then get a flat screwdriver to pry the top of the dryer away from the door panel it should have clips holding it down on both sides of the front.
after that you can see the drum with the top open like a hood of a car , look inside there are 2 screws holding each corner of the front of the dryer , they are 5/16 hex heads , remove these screws and the entire front door panel will come loose , pull the panel upward to release the lower clips holding it.
Now that this panel is removed look under the drum to see how the belt is held so you can put it back correctly , after removing the belt pull the dr om out and you will see the wheels , you can use motor oil to oil the center of the wheels and the belt tensioner. to get the drum back in set it on the wheels and roll it untill it falls into place and reassemble the rest if you have any other questions let me know and tell me how it works out.
Phil
Jan 07, 2009 | Dryers
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Squeaking kenmore dryer
Hi .thanks for the question. the noise is from the drum rollers . you can buy a drum roller kit for kenmore dryer . to repair. lift out lint screen remove 2 screws . with a flat screw driver pry the top up between the top and front at each corner. lift top 2 screws on the inside of front panel remove pull front off . remove drum . replace parts in drum repair kit . thanks the appliance doc
Oct 03, 2008 | Kenmore 63012 Electric Dryer
Dec 07, 2007 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
