Question about Homelite Garden
Model UT08580A Homelite Backpacker tool to remove carb hi and lo jet screws
KMusselmann
  • 247 Answers
SOURCE: carb adjustment tool
It is probably a star or a square head. You should be able to pick up at any auto parts store.
Hope this helps
Kurt
Posted on Mar 18, 2009
  • 211 Answers
SOURCE: Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
Posted on Dec 05, 2008
sparksflyin
  • 47 Answers
SOURCE: homelite backpacker blower # uto08083 not running
fist thing is run both the carb screws all the way in then back them off 1 1/4 turn this will be your starting point then start the blower to fine tune the carb if it starts then your carb was off giving it to much or to less fuel
Posted on Feb 05, 2009
  • 109 Answers
SOURCE: Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
Posted on May 12, 2009
  • 33 Answers
SOURCE: homelite back pack blower idles then cuts off when throttle appli
Yes you can,be careful not to bend the screws,then you can adjust the mixture.You do not have to replace the plastic caps but you can.
Posted on Jul 12, 2009
Engine runs on choke but dies without?Special tool to adjust hi /lo carb settings?
Your main jet in carburetor is fouled and needs to be cleaned out. The choke circuit bypasses it but when you remove the choke the gas is supposed to go into engine via the main. If clogged, the engine will quit for lack of fuel.
Either clean the carb and jet or replace carb. And yes, newer carbs have basically non a adjustable jets which is ridiculous since each engine is unique and has to be properly matched to new carb. Way around this is by either buying the special tool (he-- with them) or using a dremel tool to cut into head of adjuster a slot so that you can use a regular flat blade screw driver to adjust.
Oct 27, 2015 | Ryobi Garden
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
CRANK ROPE IS IN A BIND OR STUCK
Hi, if you remove the recoil housing you have a good chance of freeing the rope if it's bound. Try pulling the rope to see where it's tangled and use a screw driver to pry it loose. Good luck.
Dec 22, 2010 | Homelite Consumer Products Backpack...
How do I identify the exhaust outlet on my homelite backpacker - I believe i need to clean it
look for black /burnt looking/smelling of oil there will be some form of guard covering it , usually 2 screws holding it on ( allen or torx ) , when removed take it outside and carefully pour petrol into it and very carefully set it alight to burn out any carbon /oil deposits
Nov 16, 2009 | Homelite Consumer Products Backpack...
Mighty lite 26b leaf blower will not go full throttle, seems to bog down under full throttle, cant get a tool in the hi and lo adjustments
many current production models have carburetors that have limiter caps on the adjustments (if there are any) and the symptoms sound like fuel starvation or 'lean' condition.
carburetor gaskets/diaphragms should be replaced, and carb body cleaned with carb cleaner while apart
Nov 08, 2009 | Homelite Consumer Products Backpack...
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Jul 01, 2009 | Homelite Garden
Homelite backpacker blower # uto08083 not running
Dec 20, 2008 | Homelite Consumer Products MightyLite...
Hi
regards savumihai71
Dec 05, 2008 | Homelite Garden
Garden Logo
85 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
