Question about Dryers
Remove top of dryer - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
Inglis belt replace
1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 6) Next is to remove tension from the belt so that you can remove the drum. To do this simply reach under the drum and pull the idler pulley in the direction of the closest wall. This will give you the slack needed to take the belt off. 7) carefully pull the drum out. I usually do this by lifting up on the left from the top, using it as a handle. This is helpful because it also prevents the belt from getting snagged on anything underneath.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed.
Jun 22, 2012 | Whirlpool Dryers
Getting to drum in kitchenaid dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Jun 04, 2012 | KitchenAid Dryers
Mdg9700 need to remove front cover, which does NOT match normal maytag type bottom held by clips not screws, first look is that control panel needs to remove first but if so these are concealed.
The top panel and the control panel need to be removed first before the front panel can be removed. Once the top panel is off, the screws attaching the control panel to the dryer cabinet are exposed. The screws securing the front panel to the dryer cabinet are exposed once the control panel is removed.
Disconnect power and remove the two screws attaching the top panel to the rear of the dryer.
Slide the top panel towards the rear to clear the screw head from the flange at the bottom side of the top panel then lift it from the unit.
Remove the screws securing the Heater PCB Assembly at the left side of the dryer cabinet then flip the assembly over and disconnect the black and the white connectors from the board.
Remove the four screws attaching the control panel to the dryer cabinet then rotate it down and remove it from the dryer.
Remove the two screws in the door area and the four screws from the top of the front panel and attaching it to the dryer cabinet.
Pull the front panel forward then disconnect the interior light harness.
Lift the front panel off the tabs across the bottom and remove it from the dryer.
Reassemble the dryer in reverse order of the disassembly steps.
Apr 05, 2011 | Maytag Neptune MDG9700A Gas Dryer
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
How do I get to the gas coils?
Remove top back of dryer that houses all the switches, remove screws in lint catcher area on top of dryer. Remove screws that are attached to clamps at back of dryer that hold top on. Top should now slid forward for you to remove. At the top of front cover on the backside of it, you need to remove screws that hold on the front cover. Then slide it up for removal. Hold drum or it will fall off. Gas coils are at bottom of dryer.
Jun 10, 2010 | Whirlpool LGB6300 Gas Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Need to put a new belt on how do i get to it.
Not a fun job. Remove the screws in the top rear of the dryer.
Lift the top and remove any plugs. Lift up and forward to remove top.
Pull up and remove the front of the dryer
Remove 4 screws of the drum support.
Remove the drum.
Install belt and reverse the procedure.
Nov 03, 2009 | LG DLE0332 Gas Dryer
Took the lint screen out and forgot to put it back in and a kneehigh went in the vent and made a noise. Is there any way to get it out without repairman. I cannot see the nylon and the machine is stacked...
This being stacked makes things a lot more of a pain. Disconnect power.
  • Remove three phillips head screw at the back side of the dryer top
  • Slide top back about an inch or so and lift off
  • Remove two phillips head screws at 5 and 7 O'clock position on dryer bulkhead just behind dryer door.
  • Remove two phillips head screws on top front edge of dryer
  • Tilt dryer front forward at top and unplug door switch at top of door and light socket at top left.
  • Lift off dryer front, holding until you can unplug the moisture sensor wire at the bottom, then set aside.
  • Remove the four phillips head screws at the sides of the dryer holding the front drum support assembly.
  • Lift up assembly and pull toward you to remove.
  • You now have access to the blower.
  • Front of blower can be removed. (1/4 hex screws)
Oct 03, 2008 | LG Dryers
Maytag md 4000 dryer, removing the top?
hi thanks for the question .2 screws at the bottom of front panel remove remove front 2 3/8 screws under the top at front remove & lift top .thaks the appliance doc
Sep 28, 2008 | Dryers
Roper gas dryer
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 08, 2007 | AEG T57800 Electric Dryer
Dryers Logo
Top Dryers Experts
