Question about Proform Exercise & Fitness
I need a control panel for proform 780zlt treadmill
    New Friend:
    Problem Solver:
  • 9 Answers
Are you looking for a spare? or to buy one normally? Iconservice.com is where I look up all the parts for Iconfitness products (Proform, Epic, Gold's Gym, Freemotion, etc.)
Posted on Feb 06, 2013
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
SOURCE: console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Posted on Jul 04, 2011
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
Proform treadmill think about 375 model? This morning the panel does not work and unit wont turn on, have reset and unplugged
Possible that the control panel has failed , the processor controller . If the power to the panel is checked and there is +5 to the processor then the associated circuits are a suspect. Also check on the power supply for the correct DC voltage to the main board.
Jan 03, 2012 | Proform 4.5 Trainer Treadmill
I need screws to reattach control panel to my pro-form 590-ls crosswalk treadmill
Dear Sir:
You need to check you user manual. Anyway you must need 6 long screws philips for attach plastic-iron about 1 -1/2"-to 3/4" you can buy in any hardware.
You can download your user manual free http: //fitness.manualsonline.com or+go
www.proform.com go customer service and then parts & manuals put you model and serial number and download and ready.
sincerely.
Oct 08, 2011 | Proform Crosswalk 500 Treadmill
My proform xp 620 treadmill starts up fine and I can walk on it up to 4 mph. However, when I try to go up to 5 mph, the belt stops moving and the display screen goes blank.
1) adjust sensor reed switch or optical disk by 1/8" aprox and replace if neccesary after if the problem persist.
Chech the plug connector console panel vs. and controller board. If everything is wrong the console panel is bad.
Aug 22, 2011 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
63 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
