I have jamo cd power 15 but no amplifier
What amplifier do I need for my device
    New Friend:
  • 19 Answers
If you mean a cd player , It will hook up to any amp or reciever,
Posted on Dec 03, 2012
I was given a Jamo sub 1810, but have no instruction manual. I'm trying to hook up to my Pioneer HTP-2500 home theater system. What would be the correct way? Also if you could help me with the setup,...
Find it here...
http://www.jamo.com/na-en/support/owners-manuals/
http://www.jamo.com/images/download/779.aspx
The Jamo is self-amplified and accepts Line Level input ONLY.
The HTP-2500 receiver drives a subwoofer directly with SPEAKER LEVEL output only and does not have a volume-controlled output for driving externally-amplified devices.
May 21, 2011 | Jamo SUB 1810 Subwoofer
Power led on but no output
Try to trace the fault systematically from one end of the system to another, starting with something that you know is working
  1. Start by checking your sound source (cd player or whatever) is working by connecting it to another amplifier or computer.
  2. Check the connecting cable is working from the sound source to the amp and is not shorted out.
  3. Make sure your loud speakers actually work (briefly shorting a 1.5 volt AAA battery across the speaker terminals should produce a crackling sound without doing any damage)
  4. Check loudspeaker cables are properly connected to output connectors and are making a good contact.
  5. Try connecting something like your computer speakers (or use the microphone in jack on the computer itself) to the line output socket of the Jamo. If you can get some sound this way it would suggest that the internal output overload protection fuse may have blown. You will need to open the case to access this. NOTE if your JAMO is still in warranty take to authorised repairer otherwise you may invalidate your warranty.
Feb 25, 2011 | Jamo MPA201 2-Channel Amplifier
I'm replacing a JAMO amp.
The 201 is 100w in to 4ohms and the 101 is 50w into 4 ohms other then that there the same
Mar 24, 2010 | Jamo MPA201 2-Channel Amplifier
Home cinema
Yes, these speakers need an amplifier. So unless your DVD player features an amplifier, then you will need separate 5.1 receiver, for example Yamaha RX-V365 or RX-V465 (which supports audio via HDMI input).
Apr 06, 2009 | Jamo A102HCS5 BLK Compact Designed 5.1...
Sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Mar 29, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Jamo MPA-101 2 channel amp quit working
Check the small electrolytics on the power supply board for high ESR, Very common problem on these amps. Protect circuit stays latched due to high ripple from PS.
Mar 24, 2009 | Jamo MPA201 2-Channel Amplifier
Two Jamo MPA-101 amps not working
I can almost guarantee that you'll find bad electrolytic caps on the power supply board to be the cause of the problem. I've seen several of these with the same problem. The protect circuit stays latched due to excessive ripple.
Dec 16, 2008 | Jamo MPA201 2-Channel Amplifier
91 people viewed this question
 Grubhead
Grubhead
