Question about Digi-Tech DOD-Digitech 231 - 31 Band Per Side Equalizer Home Equalizer
I need an IR led of 4.3um for my project capnograph thats basically a medical application, so please if you can tell us the manufacturers of that product.
The best way to fine your answer for your capnograph is to call your local hospital and tall to a hospital engineer. They always work on medical equipment and can give you who the manufacture's name and phone numbers. And you may never know, maybe they just might have extra parts or the same equiptment just lieing around taking up space. Papabear
Posted on Jun 30, 2009
Science fair ideas for 10th grade?
Write your answer...
have you considered a basic motor system that causes led lights on a conveyor with a cell to shine.
Jan 04, 2017 | Homework
Can some one tell me who the manufacturer is so I can get a copy of the manual please.
Hi people ask your question all the time and all you have to do is google "manual for"+brand+model number ie: manual for Samsung TV LE32R53B
Look for FREE user manual you'll find it...CHEERS..
Mar 16, 2016 | Televison & Video
Nead to know where the IR Receiver is on the tv.
hi.
You can see the IR receiver near the standby led. normally Ir receiver and standby led are fitted on the same board. And the same board will be fitted on the frond panel of the tv. Have added a picture for your reference.
ok
Jun 09, 2011 | LG RU-52SZ51D 52" Rear Projection...
I need a I/R setup for these binos...do you have pr can you tell me where i can get one...thanks
Hello, contact Night Vision Optics they should be able to get you one. You can make your own by using an head light. Get an IR bulb, or change the lens to IR lens. If you want to high tech then get head light will IR LED's. If the white LED's are used don't use IR lens over this white LED's because of the light spectrum is different for the the LED's than incandescent light. They will have to be changed IR LED's..GB...stewbison
Jan 09, 2011 | Kalinka Baigish 12 Russian Night Vision...
Sir pls help me with my project in visual basic according for program in medical inventory system thank you
Which Kind of help??
Want to know about medical inventory system
Then try These!! Download manual to know the specification!
Or Download Similar Project from here!!
Regards
Vikas Agrawal
MCA
Feb 03, 2010 | Microsoft Visual Basic 6.0 for PC
My REMOTE CONTROL FOR TV HAS VERY WEEK RANGE CAN I MAKE IT POWERFULL
Try replacing with new Cells ....
and clean the IR LED of the remote ...
clean the IR receiver of the TV tooo.
basic range is 15feet it should work if it is working
Sep 28, 2009 | Televison & Video
Projector
Change the bateries,clean the IR LED'S,both the remote,and the projector.Some kind's of functions was set for use before.it was not turn off or clear out of the memorys,that why u getting a not applicable message.
Aug 19, 2009 | Televison & Video
I have a DCT 700 Cable Box and I need to know where the IR eye is so I can line up my IR Blaster with it
as far as i understand the ir sensor is most likely in between to the 2 front leds (power and message light)
this is only from past experience with Motorola products and other ir products
the sure way to tell
if you have a video camera that can work in night vision (either security or personal) you should be able to see the opening in the see thru plastic when help close enough to the display
May 01, 2009 | Televison & Video
Rear Camera Light LED
try online at the sony ericsson website
Aug 28, 2007 | Sony Ericsson W550i Cellular Phone
I just can't get it to work, new batteries and all.
First check if the remote control is sending an infrared signal. If the LED is flashing, this does not mean the Remote control is sending the IR signal. There is a separet Infrared LEd that sends the signal. To check the IR, point the remote control in a video camera or any camera with real-time monitor (phone cam, webcam, etc.) and press any button. You will see a white flash coming from the Remote control. thjis works best if the camera is black&white, for color camera, the IR is still visible but quite faint. Another way of checking the IR (if you do not have a camera) is to press the RM in front of another device with remote control and while doing so, press the correct remote control . If that other does not function or functions erratically, then the remote control in question is emitting an IR signal. If there is no IR coming out, the solder conection of the IR LED might be the problem. It is rare that the IR LED will be damage because the remote control is only 3 volts. If the remote control does emit an IR signal, then the TV remote reciever is defective. I had this problem with a CD player that I have fixed. The IR reciever looks like an LED (dark colored) with three pins (V+, signal, ground). Cost less than $3
May 18, 2007 | Jensen JER-323 Remote Control
Open Questions:
333 people viewed this question
Top Digi-Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
