Question about Olevia LT42HVi 42 in. LCD Television
Olevia 42" tv no sound no power sometimes
  • Olevia Master
  • 933 Answers
Start with having the power supply capacitors checked, common problem on older Olevia sets!
Posted on May 14, 2013
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
freetek
  • 5568 Answers
SOURCE: my olevia 42 in lcd tv the power does not come on
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload and the power supply for the backlight may be at fault.
Posted on Jun 14, 2010
SOURCE: Red spots on Olevia TV
pixels are bad/going dead. look up dead pixel issue on PSP for really good explanations, or just trust me.
Posted on Mar 31, 2008
  • 93 Answers
SOURCE: Year old 42 inch Olevia 1080p won't turn on...
Sounds like you need to download the latest update, unfortunately Olevia went bankrupt and doesn't answer the phone. If I find out anything that is being done to correct the situation, I post it
Posted on Sep 17, 2009
  • 11800 Answers
SOURCE: I have a Olevia 42
Popping sounds means that there's a discharge inside the tv. Since the HDMI inputs have also failed my guess is that the 20 volts power rail from the PSU has problems, most likely caused by failing capacitors. The tv must be opened and that rail checked. This requires some electronics expertise, if you don't have it then it's time to call a repairman - his labor bill will be much higher than the price for the replacement parts.
Posted on Jun 28, 2010
How to remove the wiring harnesses from their connectors on the 42" Olevia TV
Exactly what harness are you trying to remove?...are you referring to the flat ones that go from the TCON to the panel? or the ones that connect the power supply to mother board
Aug 02, 2017 | Olevia Televison & Video
I have a olevia 42 inch 242FHD-T11 it is around 3yrs old and now it will not turn on with the remote so when I turn it on manually it comes on but with no sound after I do this 3 or 4 times the sound...
I am also having this exact same problem... except sometimes the power wont even come on with the power button on the tv. did you figure out what it was?
Thanks
Sep 21, 2010 | Olevia 252T LCD TV
Power light is on but no picture or sound
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Olevia LT42HVi 42 in. LCD Television
My olevia 42in not getting power is it the power supply thats going out sometime it turns on
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 22, 2009 | Olevia LT42HVi 42 in. LCD Television
Sep 17, 2009 | Olevia LT42HVi 42 in. LCD Television
42" TV has sound but no pictures
yea it sounds like a main-board or inverter board.. sounds like the panel of the television is loosing power and you are still getting sound..
Olevia did go out of buss.. but i know this 3rd party repair center called Amergence technology is offering to repair Olevia's. But the thing is that the whole television will have to get service they don't sell parts so you might want to give them a call and get an idea on the repair quote.. 866-965-3842
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Olevia 42"
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
554 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
