Question about Canon CLC 4000 Copier
Clc color copier error code E061-0321
Copier powers up fine then has the error code E061-0321 Switch power Off and On again.I turn the copier off and on. The copier proceeds to power up then show the same error code. Over and over again. Any idea on the problem and how to correct it? THANKS! brian
  • brian27626
    brian27626 Dec 03, 2012
    Once the copier went to copy mode and copied for about three minutes then the error code returned. I unplugged the copier and plugged back in several times. Maybe that had an effect.
  • JC Gamboa Dec 04, 2012
    I can fix it..but is going to cost you $ 100.00 e mail me to mail@popdigitalmty.com
    Habit-Forming:
  • 96 Answers
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Posted on Oct 10, 2017
muleskinner2
  • 270 Answers
SOURCE: Error Message E020, 0400 for canon CLC 1120 Color copier
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Posted on Nov 14, 2007
checkitright
  • 1362 Answers
SOURCE: Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Posted on Dec 20, 2007
SOURCE: 5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Posted on Jan 12, 2008
SOURCE: CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Posted on Jan 21, 2009
SOURCE: Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Posted on Mar 14, 2009
Ir5000 error codes E804 -0000
dc power supply fan. open the left covers and you will see the dc power supply in that board you got fan. and switch on the m/c if it's rotating.
Jan 11, 2013 | Canon CLC 1120 Color Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
E 803 when machine is turned on
Hello sir;The error code you display including so many mesnings; transfer unit level switch, left front interlock switch, DC power supply, DC fuser board, DC driver board, CPU board, DC power cut relay.
My suggestion go to check al those switch first if still don't work then go to others.
Jul 18, 2009 | Canon CLC 1120 Color Copier
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
E005 0100 Error
asfter clearing the error code turn the machine off then on again, if that dosen work remove the web then clear cut off turn on
Nov 25, 2008 | Canon CLC 1150 Color Copier
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
My CFC800 gives e 005 eror.
check if your adf cover s well position& conected & checkyour power.
thanks
Oct 05, 2008 | Canon CLC 1000 Color Copier
ERROR CODE
there is a problem with the fuser, replace thermistor or thermofuse
Aug 29, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
55 people viewed this question
old marine
old marine
