Question about HP Pavilion Dv7-1232nr Dv7-1135nr 17.1" Wxga Lcd Screen Complete Lp171wp4
My hp pavilion dv7-1135nr turns off with no warning when plugged in
My friends computer stopped working. Lights where blinking. I replace the motherboard (but not the cpu) It is now working but after several minutes in cuts off, with no warning. It is hot on bottom, everything was clean. Can not hear fan so not sure if it is working or not. I did not change anything in bios. I am going to see if I can see fan working or not. Do you think the cpu is bad? or a bad motherboard?
  • HP Master
  • 1,881 Answers
Why replace the most expansive part first?
its overheating. I bet ONLY.
the fan must blow, if its dead fan , it will over heat slow down CPU then will shut down. all PCs do that not cooled properly.
i guess you pulled heatsinks to after all , old CLU still there.
so used top brand Heatsink compound?
if yes, the the heat goes down that heat pipe to the radiator in the fan box, if the fan blows the heat blasts out the vents.
I use SHIN grease
nothing better, 4bucks
https://www.ebay.com/sch/i.html?_odkw=Shin-Etsu+micro&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XShin-Etsu+x23.TRS0&_nkw=Shin-Etsu+x23&_sacat=0
cools my hot i7 in my elitebook, very good. tried, many types, nothing beats this.... my other book same is i5 and can use any grease.
see? the i7 runs way faster and way hotter, as all do fast.
Posted on Jul 26, 2017
  • HP Master
  • 16,589 Answers
Get a program called speedfan and try to install it before it crashes, put it in the refrigerator to extend the run time. Almico.com has the free application speedfan. that program will tell you what the temps are. You could also look at the event viewer logs to see what they say under the system tab. The bios changed when the motherboard changed. However it sounds like an overheating issue. Did you put new heatsink compound on the CPU
3 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Posted on Jul 10, 2009
  • 134 Answers
SOURCE: HP nc8230 no BIOS setup and system time error
the simple thing is that are the both system compartible?so if they are not just compartible go to the local pc outlet in your area and get a compartible one better you go with the faulty screen so it could be easily verify.
Posted on Sep 18, 2009
HP pavilion dv7-1135nr turns off with no warning when plugged in
Neither, if it is hot, its because the fan is not working. Overheating will cause shutdown. Also, cleanig it would help dissipate heat when you replace that fan.
Jul 28, 2017 | HP Pavilion Dv7-1232nr Dv7-1135nr 17.1"...
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
Light around power cord goes on and off. Will not charge Plug on computer blinks on and off. The cord gets hot.
> the cord gets hot.
WARNING!
You have something DEFINITELY wrong with the AC adapter, that could ELECTROCUTE you.
DISCONNECT IT. DO NOT USE IT.
Buy a replacement (look on eBay, or look on HP's web-site: http://support.hp.com
to buy a factory-replacement part).
Dec 20, 2010 | HP Pavilion DV6700T Notebook PC
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Plug the computer in and the light on the back and in the front
Try a different power supply or another thing you can remove the ram and reseat it
lety me know if this helps
Mar 14, 2009 | HP Pavilion a705w PC Desktop
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion Dv7-1232nr Dv7-1135nr 17.1" Wxga Lcd Screen Complete Lp171wp4 Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
