Question about Electrolux EL5010A Bagged Upright Vacuum
How to fix the suction in the electrolux aptitude vacuum
chris321918
  • 32 Answers
SOURCE: NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Posted on Jan 21, 2009
LizDahl
  • 75 Answers
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
Agent Don
  • 310 Answers
SOURCE: Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 24, 2008
  • 38 Answers
SOURCE: Electrolux "The Boss" 4110 Vacuum - Have to hold power button?
It sounds like the on off Switch is broken.
you need to replace it or tape/glue it down and use the plug as on of switch.
Posted on Jul 12, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
Wand has no suction when detached from vacuum
The Electrolux vacuum is the source of the suction; when disconnected it will not have suction. Am I missing something here?
Mar 13, 2015 | Electrolux Vacuums
My upright electrolux vacuum will not suction from the wand. How can I fix this?
HI, it's Jim from Crucial Vacuum!
If your Electrolux vacuum is losing suction from its wand then most likely there is a clog in your vacuums hose.
Stretch out your vacuums hose as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
Another area to check is your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum. Empty your dust filter after every use to promote optimization in your suction.
You can purchase replacement parts for your Electrolux vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=electrolux&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 08, 2015 | Electrolux Vacuums
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
Jeremy Lerner
Aug 05, 2014 | Vacuums
No suction
CHECK THIS CHECKLIST OUT!
http://www.quickanddirtytips.com/house-home/diy/how-to-fix-a-vacuum-that-lost-suction?page=1
Jul 13, 2014 | Electrolux Guardian Bagged Canister Vacuum
How to fix expelling dirt from electrolux versatility?
sounds like the vacuum is blocked.Turn vac on its back and check the area where the dirt goes in,there is probably something stuck in there....
Jun 23, 2014 | Electrolux EL8502 Versatility Bagless...
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
NO SUCTION
Jan 21, 2009 | Electrolux Central Vacuum
1-800-896-9756
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Electrolux EL5010A Bagged Upright Vacuum Logo
96 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
