Kenmore washer mod.22622100 how to replace lid switch
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
IFIXALL
  • 868 Answers
SOURCE: kenmore 110.92380200 washer lid switch replacement
You first have to remove the 2 phillip head screws on your face panel.There is one on each side located about 1 inch from the front corner.tThese 2 screws are holding down the entire front timer panel.Ok,now lift up & forward at the same time so you can swing back this timer panel and get it to balance back out of the way.Now, it becomes a little harder,locate the harness that your lid/spin switch is on by unscrewing the 2 screws on the spin switch.Pulling the bad switch away from your cabinet will expose the harness ,that way you will see where it is plugged in.After unplugging it your now ready to plug the new one in and just tuck in the harness in the cabinet.Flip the timer panel back down and screw it back down.Your done !!!
Posted on May 20, 2008
AlmostBob
  • 550 Answers
SOURCE: I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Posted on Oct 02, 2008
  • 1122 Answers
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Posted on Oct 26, 2008
scottowa
  • 87 Answers
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
I need the installations instructions for a Kenmore washer Mod 11020882990 for the lid switch Stella
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020882990/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Oct 26, 2010 | Kenmore Washing Machines
Mod. 110.29852992 80 series will not pump out
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29852992&pathTaken=partSearch
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips,pull the console forward and tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
May 12, 2010 | Kenmore Washing Machines
Kenmore washer won rinse waer out model 22622100 any suggestions?
See the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22622100&pathTaken=partSearch
I'm assuming that it won't drain. Will it spin????
If it will neither drain NOR spin. I'd check the Lid Switch:
If it WILL spin but simply won't drain. I'd pull the cabinet (See above) and check the pump and hoses for any blockage.
May 07, 2010 | Kenmore 22622 Top Load Washer
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
I need help replacing my switch lid on my Kenmore 70 Series mod. # 110-22722100 Washer. Can anyone help me with this??
if you have a gray switch than you nead to bypass the switch.if you replace the switch it will brake again.you do not nead a door switch.
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Require a new lid switch to fit a model 22622100 type 111 Kenmore washer, also require a service manual to find out how to remove the washer top to instal the new switch
http://www.appliancepartspros.com/part_details.aspx?part_id=3100001&rdr=%2fmodelsearch_model.aspx%3fmodel_id%3d415134
Check out that link for the switch.
As for the washer top, you don't remove just the top, you remove the whole cabinet. Remove the two end cap trim pieces from the control panel, (just pry them off) remove the two screws securing the panel to the cabinet. Flip the control panel back on it's hinges. Unhook the lid switch wire harness, and use a screwdriver to pop out the two gold clips that secure the cabinet to the back panel. You should now be able to tilt the cabinet slightly forward (towards yourself) and pull off the base. You now have full access to replace the lid switch.
Dec 30, 2009 | Kenmore Washing Machines
My Kenmore washer 22622100 is broken - the washer stops between the rinse and spin cycle. It simply stops.
The following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
Replacements can be purchased at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. All these sites offer great service with competitive pricing, so shop all of them for the best deals. The first two web sites have excellent exploded view diagrams of your appliance to aid in parts location and assembly.
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series mod 110225842400 stopped working during cycle. Tub won't drain and will not agitate.
Hi, When the washer is in spin or wash cyles, do you here any motor noises? It sounds like the lid switch might be bad. Sometimes you can actually see if the lid switch is broke or not. Please let me know if The lid switch appears to be the problem or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 20172 Top Load Washer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
