Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Frigidaire gallery top load washer is leaking and will not wash big load
It is leaking from the bottom when fully loaded and wont spin
  • Official Brand Answer
  • 4,342 Answers
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Posted on Dec 03, 2012
SOURCE: Frigidaire front load washer model LTF2940FEO. As
if water on floor at base of machine,most likely the pump is leaking or the pump hose connections for drain pump need attention either replacement or clamp could just have woked itself loose.
Posted on Oct 10, 2012
huuum
  • 750 Answers
SOURCE: frigidaire washer model FWX833AS1 top load
Hello Lcl2610.
welcome to Fixya,
My name is Huuum,
How old is your machine?
I have found some reasons of what may be the matter!
List of thinks to check
1.Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
2.Faulty Direct Drive Coupling
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
3. Faulty Water Level Switch
If the water level switch is not resetting once the water is drain, power will not be available to operate the motor during spin. Check the water level switch for proper operation.
4.Will not drain and displays F/02
The error code F/02 will be displayed if the drain time exceeds 8 minutes. Press pause/cancel twice to remove display. Check the pump filter and wiring connections on the pump. If all looks good, replace the pump.
You may want to use a pro, rather than attempt this project your self.
Let me know how it goes!
Thank you Huuum.
Please remember to leave a rating
Posted on Oct 21, 2008
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
Ben-mrfixit
  • 68 Answers
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
Posted on May 02, 2009
Frigidaire washer repairs
it almost has to be the belt think the front comes off to check it out
Sep 01, 2014 | Frigidaire Gallery GLWS1339EC Top Load...
Water leaking from the buttom
your washer is off balence its causing your tub from inside your washer to splash out on spin cycle adjust legs get a level then put on top[ washer see if its balanced then try a load.
Jan 26, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
Washer does not spin on spin cycle?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 16, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
My washer wont spin it washes but wont spin i have a Frigidaire Gallery
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 26, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire front load washing machine won't drain
heatman101
Aug 31, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
During spin cycle, water leaks from bottom of washer
Tub seal is bad.At high speeds it will leak.needs replaced.
Nov 04, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
