Question about Hardware & Accessories
Where are pins on smart electrician 24 hr timer
  • 5,245 Answers
1) Copy following link for setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
2) Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Add comment and describe timer in detail
Posted on Dec 02, 2012
3 Suggested Answers
c_dyer01905
  • 27 Answers
SOURCE: Diehl Spa Timer
http://www.swimmingpoolsetc.com/sbb-3-40-0009.htm
P.S: I was just looking for this and stumbled across it myself...
Posted on Dec 12, 2010
SOURCE: An electrician installed a new Tork 1103 24 hr
After removing the timer motor and allowing it to run separated from the switch for 45 minutes with a piece of tape wound around the motor shaft, I discovered that the motor is just humming, and not moving the shaft gear. I need a new timer motor.
Posted on Jun 26, 2012
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
How do i program it or wer can i find a user guide
It looks like you turn the dial to the correct time of day, watching am & pm times.
Push down the pins when you want you load or two loads to operate.
That should do it.
Gary
Dec 16, 2010 | Ecoplus 24 Hr Dual Timer Eco Plus Analog...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Looking for timer pins-trippers
The Paragon 4000 series uses the Paragon X2772 tripper
Google search for Paragon X2772 tripper turns up sellers
Pair of on-off trippers appear to sell for about 9$
Oct 28, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
How do you set on and off mode???
Tork, GE, Woods, Intermatic make a series of timers that have pins
The pins push out for OFF or ON times depending on brand
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
1,530 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
