Question about Samsung (HD080HJ/P) 80 GB SATA Hard Drive
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Problem with Samsung HD080HJ/P sata hard drive How can I attach a Samsung hard drive HD080HJ/P as a slave to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seem to be no master/slave settings on the hard drive. The computer in which the Sansung drive is installed cannot be booted due to a fault in the motherboard and I am hoping to transfer my data to a new computer. Thank you. illingworth42@btinternet.com
  • Samsung Master
  • 2,072 Answers
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Posted on Dec 02, 2012
SOURCE: Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
Posted on Jul 19, 2008
  • 17 Answers
SOURCE: My PC don't recognize HD Samsung Sata II 250gb
If you mean the drivers for your SATA harddisk, you should have gotten a CD with your motherboard that contains drivers they might be labeled as RAID, sata, or EIDE controller. when you click that it should prompt you for a floppy disk to put the drivers on, you need to put a floppy disk in drive A and then extract the RAID drivers to your floppy, when installing windows press F6 at the begining of the installation and it will act like it didn't work for a minute and then it will pop up asking you something, you press S and then you will be asked to insert your floppy disk. It might ask you if you want to install the x86 or x64 drivers, x86 is 32bit and x64 is 64 bit, if you don't know which you are using it should tell you somewhere on your windows disk. another option is to get a sata controller that isn't part of your motherboard, it would be a pci-e card and it would come with drivers. I don't know where you could download your drivers from because I think the driver you need is specific to the type of SATA controller your motherboard has in it, but I do know that seagate and western digital have sata drivers available as well for their harddrives so I don't know what to tell you. best shot is your motherboard driver CD.
Posted on Dec 18, 2008
SOURCE: I've connected my Samsung 250GB HD250HJ SATA drive
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Posted on Dec 05, 2009
Testimonial: "Thanks for your advice. I've found the jumper settings."
pgh_pa_guy
  • 2992 Answers
SOURCE: can i put a samsung
Unless the motherboard in your system is different from the one shown on HP's site, the answer is no, you can't install the drive. At least you can't install it without additional hardware, which I'll describe in a moment. It looks like this board only has SATA connections for drives, which is becoming more common. So there is no conventional (i.e., old-fashioned) IDE connector for the data cable used by your Samsung drive. There's no place to plug the in the drive.
What you'll need if you want to use a parallel IDE drive is an expansion card like this one. There are many similar cards; I'm just using this one as a sample. The card installs in one of the PCI-E slots on your motherboard, and it provides the IDE connection you need. In addition to the card, you'll need an 80-conductor ATA-133 IDE cable.
With SATA drives, there isn't the master/slave designation since each SATA device has a direct connection to the motherboard. With the parallel cable, you can have two devices connected, so one needs to be designated as the master and the other one as the slave. The master is the drive connected to the plug physically at the end of the cable, and the slave is the middle plug. When you install your Samsung drive, set it for "master" or "single" drive as required. Some drives have a special jumper setting when used alone, while others need to be set as master even if there is no slave drive present. The jumper settings are usually marked on the drive, or you can check at Samsung's website.
Hope this has helped. Thanks for using Fixya!
Posted on Jan 20, 2011
J-Chris Ward
  • 731 Answers
SOURCE: My samsung sata hard disk
You can buy a SATA dongle that plugs in to the hard drive and plugs into the USB port on you computer $20 or buy a external SATA case to put the hard drive in $40 at most computer retailers.
Posted on Feb 06, 2011
Desktop Computer Graphics Drivers
Try to download the compatible driver from the AMD Radeon website.
Mar 12, 2014 | Dell Optiplex 755 Ultra Small Form Factor...
It is dell optiplex 755 ,when i on my pc it freeze after a certain seconds & not display to the monitor.
Do you have a good working monitor that you can troubleshoot with? I would make sure the monitor isn't going bad first. Then if you're still having the same issue, try re-booting in safe mode and run a virus scan.
Oct 23, 2013 | Dell Optiplex Gx755 Core 2 Duo 2.5ghz 4gb...
I have dell optiplex 755. Does my system support ati radeon 3650?. Also recommend me any else card which is suitable for my computer
what model is this small form factor ? mini tower?anyhow, here are the things that you may consider .
if its a small form factor unit then you may need to get a video card that is Low Profile
and also consider the power supply :
The ATI Radeon HD 4650 512MB Low Profile PCIe x16 graphics card should work fine with the 275w PSU.
Max power draw is 48 watts
Oct 13, 2012 | Dell Optiplex 755 Minitower Desktop...
Jumper setting
you can keep master either hard disk or rom not both. there must be one slave and one master for one ide slot
Jun 12, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Configuring dell optiplex 755 sff
on the back of each device their should be a jumper on the right side next to where the ribbon cable plugs in. Remove the jumpers and replace them into the slot thats for "Cable Select" Their should be a picture on the top of the device if they aren't labeled. You can also put the jumper for 1 as "Master" and the other as "Slave"
Apr 20, 2009 | Dell 16X DVD±RW Serial ATA Internal Drive...
Computer does not see hard drive or cd rom
Use separate cable for both the hard drive.
Make master to the one which is bootable,restart your system and just check bios setting whether both the hard disk are detected or not..also under boot device check first boot drive is hard drive which is master and bootable..
Jul 21, 2008 | Dell OptiPlex GX260 PC Desktop
Samsung (HD080HJ/P) 80 GB SATA Hard Drive Logo
847 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
