Question about Xerox WorkCentre M20i All-In-One Laser Printer
Xerox M20i scan to e-mail
I am trying to configure the scanner to send mail . I follow up the instructions in the manual . when I try to test it I got LDAP commutation error and smtp error .
how you can I configure Xerox M20i Work Centre to be able to scan to e-mail.
Thanks
  • ayman_sobhy Jan 12, 2009
    hi tryit
    this printer can scan to mail. but not to desktops . i can send mailscans from it . just when i try to qurey the GAL address list . it come with LDAP commutation error. it can store 100 local e-mail.
    thanks for reply
  • 6 Answers
This may be an old topic but M20i will scan via Ethernet. That's why it's called "Scan to E-mail". I would check your LDAP settings and make sure your CN= user container and your DC= entries are correct. You may need to use LDAP on port 636 and if you need authentication, provide a username and password with the appropriate permissions.
Posted on May 10, 2011
    President:
  • 2,072 Answers
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Posted on Jan 11, 2009
  • Rick Kasper Jan 15, 2009
    Most LDAP errors I have seen with Xerox products are non characters in addresses. something like _- + is in the address.
    That is the normal issue with LDAP I see.
    You can call 1-800-821-2797 and ask for second level support. They shold be free and able to specifically help with your issue.
    I didnt read your initial post real well. Sorry.
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Download xerox m20i scanner software
Go to Xerox.com and under drivers and downloads for the M20i , download firmware version 3.02.
And follow the instructions to put the new software onto your printer.
Jun 22, 2011 | Xerox WorkCentre M20i All-In-One Laser...
LSU error displayed on Xerox M20i
LSU stands for Laser Scanner Unit. It comes up only if you are trying to access scanner services like scanning a document, using fax or simple scanning.
If it's coming continuously you might need to check connectors within the scanner. Best way is to call a technician from Xerox or take it to their store.
Jun 21, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Help! I'm trying to print a configuration page on a WorkCentre M20i
Hi, you can print a configuration page on the M20i by following the steps below:
- Press the Machine Status button - Select Reports, then press Enter - Select Connect Page, then press Enter
The configuration page will print out. For configuration page instructions for other copiers or printers, visit the How to print config pages website.
Jun 02, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Have a Xerox M20i Copier/Scanner/Fax. Display indicates "Scanner Locked" Cannot make copies nor fax out. Please help
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Jan 18, 2011 | Xerox WorkCentre M20i All-In-One Laser...
When I go to send an e-mail from my M20i and it gives you the option to "Send to Myself?" How do I change the e-mail address to mine?
you can configure that by access the web page of the device > Properties > Services > email Settings > From field Options
Mar 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
I get an SMTP error when i try to emali from my Xerox Workcentre M20i. What can i do to scan or e-mail without being directly connected to the printer via parallel port or USB?
That is not true i work as a IT Spec for the Kentucky Army National Guard and we have over 20 M20I series printers in which we have set up to scan to email. None of these printers are hooked up directly to the computer and they all have the ablity to scan to email. if you printer dose not seem to have the ability they you will probally just need to update the os. Here are the steps to get it set up.
  1. Connect the printer to the network
  2. Print a network config sheet
  3. use IE to connet to the web based interface useing the printers IP
  4. Click on the properties tab
  5. hit the little plus sign by connectivity
  6. do the same with protocols
  7. find and click on smtp server
  8. add ip address in the ip address and if your server requires athenticating type in the user name and password
  9. if for some reason the maxium message size has undefined then you will need to complete reset the printer or you will get an error it needs to have options that can be selected.
  10. now go to services
  11. then email settings
  12. select apropriate modes and the default from address
  13. if you want to set permissions to the device you can do so under user authintcation
  14. you can also set up the LAB and GAB
Note:
some web sites may not allow you to suer this function one alternitive is to set up a local smtp server on your network and create a mail box for yourself then you will just need to put your smtp server address in the instructions listed in step 8. I hope this helps.
Jan 28, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Have a Xerox M20i. Copy comes out light. Toner should be OK. Prints fine. Scans fine.
You need to clean the scanner. You can try doing the shading adjustment to calabrate the scanner but most likely the mirrors are hazed up. Since you can print fine you eliminate the laser.
To do the shading adjustment, you need to press in order,,, Menu # 1934, You will see a " T "on the screen, that will be the tech mode. Press the machine status, then go to maintenance, then scroll to shading. Place 5 sheets of white paper on the glass and then run the shading adjustment. turn the machine off and on, and run copies again. But most likely you will have to take the scanner off and clean it.
If you want to clean the scanner let me know, I will send you directions on how to do that. The mirrors in that scan head tend to haze up.
Jan 06, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Oct 25, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
3,049 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
