Question about Kenmore Kitchen Ranges
Kenmore stove model number c970 652231 clock - Kenmore Kitchen Ranges
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
SOURCE: Kenmore 665-9580 error code ''E1 F2''
What happened I am getting the same error LCD Message.. TX... Steve in Florida
Posted on Feb 14, 2010
TheMobilian
  • 8220 Answers
SOURCE: Kenmore range model number 790.9568330. Stove
Check your electrical receptacle, breaker, and power cord.
Posted on Mar 15, 2010
  • 949 Answers
SOURCE: I can't find my model number on my Sears Kenmore
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
Posted on May 17, 2010
Kenmore stove
here are instructions for a Kenmore, of course they may not apply to your model, but then you haven't specified your model so it is difficult to help!
do let us know if they work
Press "Clock."
Enter the time using the number pads on the right-hand side of the clock display.
Press "Start."
Press and hold down "Clock" for six seconds, until "CLO" disappears and "12hr" or "24hr" appears on the display. Press "Flex Clean" to choose between the 12-hour or 24-hour display. Press "Start."
May 15, 2014 | managemylife.com
I wana fix the time for this stove
tahts should help
http://www.ehow.com/how_7419929_set-digital-stove-clock.html
http://www.youtube.com/watch?v=iQU9Kv2yfvc
http://www.ehow.com/how_8153132_set-clock-kenmore-elite-stove.html
Nov 06, 2012 | Kitchen Ranges
My stove is flashinang and beeping f1....model number 790.94859301 whats it mean ...is my kitchen gonna go boom
that code says you have a problem with the clock assy. and it also has a computer board built into it,the part number is 316557511 and it's around 100 dollars.you can try unplgging the stove for 5 minutes and plug it back in,if the code comes back change out the clock assy.
May 11, 2011 | Kenmore Ovens
I can't find my model number on my Sears Kenmore Gas stove. Several times now the stove has beeped then kicked out with EO and F2 showing in the clock area. The stove was bought in 2000 or 1999. Can you...
May 17, 2010 | Kenmore 75012 / 75014 Gas Kitchen Range
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
sounds like you need to replace the oven temperature sensor.
Nov 07, 2009 | Kenmore Kitchen Ranges
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
