Question about Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier
When I turn amp on there is a loud humming that does not stop.
The humming is very loud. with all controls turned completely down to one.
  • 93 Answers
I do not suggest putting a mono guitar male plug into any headphone jack because one side of a stereo signal,for example, would be shorted to ground. You might burn out that side [left or right] of the headphones jack. Anyway, with the amp on and humming, pound the amp chassis or cabinet. If this affects the level of noise, remove the chassis and reflow the solder connections to the two large filter capacitors [with the power disconnected.
Posted on Dec 26, 2015
  • 91 Answers
Try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Posted on Jan 16, 2013
2 Suggested Answers
  • 17 Answers
SOURCE: when I turn on the amp, I get a loud hum. plugging
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
Posted on Feb 23, 2011
Fender Hot Rod Deville 212 sounds ok then LOUD HUM
On mine, the guitar input jacks get tarnished and causes all kind of interference and noise. Take a Q-Tip soaked with WD-40, run in down into the jack and brush up and down. Don't overlook the filter caps as they are a common cause of noise. You need a capacitor checker (the older tube type) to thourghly check those out.
Sep 05, 2014 | Fender Musical Instruments Corporation...
My sc40r amp started humming really loud after i had turned it on... it played perfect the night before... but when i went to go play it this morning it started humming really loud then stopped and began...
You take it in for electronic repair. Unless you are electronically adept at troubleshooting and repair this is not DIY. Probably one side of the PA transistors has shorted. You can blow the speaker if you keep trying to use it this way.
Sep 24, 2011 | Rogue SC40R 40W 2x8 Stereo Chorus Guitar...
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Just a loud hum when turned on.
Hum is always connected with the presence of AC interference into the signal path of the amplifier, which means the audio amplification is mixed with the ac ripples.
So this can be a break down with the power supply as a possible tank capacitor or a stabilizing capacitor in the main power or the sub sections of the amplifier or pre- amplifier.
Feb 11, 2011 | Fender ® Frontman 10G Electric Guitar...
The amp plays fine for about 15 to 20 minutes, then an extremely loud, over powering hum/buzz takes over, and then the amp has to be turned off, but the problem persists. I've tried several guitars,...
You say the "tubes are fine" I take it that you have either replaced them with new or used a very sophisticated tester on them. A heater-cathode short might cause the symptom. There are a bunch of tests I would want you to run alnd get back to me with the results.
Heat up the amp but DO NOT play anything into it for the usual failure time or more and they start to play i... did hum occur WITHOUT playing? With all volume controls down does the hum occur?
The right tools is an oscilloscpe to fing out if the filter caps are good. These are C31, C33, C35, C36.
With hum present in failed stater, plug in a grounded plug into the power amp in jack... if hum is stiil there, check the +/- 16 volts regulating Zener for ripple. get schematic here:
http://elektrotanya.com/fender_hot-rod-deluxe_sch.pdf/download.html
Jan 29, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
May 05, 2010 | Music
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
On power up there is a loud humming even with volume at 0
I would also be inclined to check all the larger electrolytic capacitors in the power circuits as well for AC bleed.
Feb 11, 2009 | Yamaha Electric Guitar
Open Questions:
See all Fender Frontman 212R 100W 2x12 Guitar Combo Questions
Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
342 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
