Question about Kenmore Dryers
I have a Kenmore electric dryer, Series 90, Heavy Duty, King Size Cap.. Model #11050902990. It has been working fine till last night, when I pushed the start button and nothing happened, no sound, not
Model # 11050902990 Series # MK 459990. What can I 'check' out myself, before I need to contact a repairman?
    Scholar:
  • 177 Answers
Don't do this if you don't know to check electrical components. Check for 220 volts at terminal block where the power cord connects to at the dryer. Check from one outside terminal to the other outside terminal. If you have 220 volts this means the power cord, wall outlet, breakers & main box are good. If you don't have 220 volts check the door switch, push to start switch , ohm the input wire to the output wire on the timer with it set on timed dry if you get 0 or near ohms timer is ok if you get infinity meter don't move you have a bad timer wire colors most likely black input & blue output this is not always true so check your diagram. Hope this will help.
Posted on Jun 17, 2014
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
That model number is for a washer.
Posted on Dec 02, 2012
larryyb
  • 291 Answers
SOURCE: coins stuck inside dryer fins
raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Posted on Nov 30, 2008
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: Have a Kenmore 70 Series,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite heavy duty king size quiet pak 1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^&
Posted on Sep 30, 2010
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore 90 series heavy duty model 67902, when I push the start button the motor turns on briefly but when I let go of start button it stops.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Kenmore Dryers
Mar 17, 2009 | Kenmore Dryers
Where to reconnect yellow-red wire on series 90 heavy duty
At about the 4 oclock position look had for a male spade clip mounted between the inner and outer front panel. Look inside the panel and you will see the metal stripes below the filter that collect the wetness data from the clothing as it tumbles past. Great question! Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Feb 18, 2009 | Kenmore 62602 Electric Dryer
Coins stuck inside dryer fins
Nov 30, 2008 | Kenmore 74602 Gas Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
