Question about Hyundai 2009 Genesis 3.8
My genesis remote will not lock car doors
Can not get it to lock the doors or unlock them
  • 3 Answers
Is your remote a part of the key? Meaning is it a key FOB like in the dodge line of cars? Or is it a separate remote?
IF separate, first check for major damage to device (water?). If none, you may need new batteries!
IF you have a FOB, again consider damage which requires dealership replacement. This is most likely the answer if your extra key FOB that came with the car still functions properly. Also some FOB require batteries (Call dealership to see if yours does).
IF FOB is not the answer or if your car does not even have a FOB, then it is posssible that your modulator that controls that doors response to the remote or FOB has gone bad. This is bad news and can be expensive to fix. Has to be done by dealership because it usually requires the dashboard to be remove to access the needed area. This is true for a Charger and a BMW. Hope that this helped. Repost with more info if you need more help.
Posted on Dec 01, 2012
Testimonial: "You were right the FOB for my 2009 Genesis needed new batteries, I just replaced them, and everything works fine. Thank You very much. Charlie Smallman"
Driver side door will not lock/unlock with the remote, but the other doors will.
no you needs a new lock actuator on that door its about $90 installed,
all the locks are on same circuit . sorry about the bad news :(
May 01, 2016 | 2003 Hyundai Sonata
I have a 2009 elantra and when doors r locked and I hit the starter the car lights blink twice and doesn't start! It was a factory install by Hyundai . The car is an automatic . What do I do? Thanks
I would return it to the installer
My 2012 Hyundai Elantra Wont Start - CarGurus
www.cargurus.com > Questions > Hyundai > Elantra
CarGurusJul 30, 2013 - My 2012 hyundai Elantra GLS would not start this morning. ... I hit my door unlock on mt Key fab and the doors unlocked fromt here I proceeded start my car.... it and it wont turn over just makes a light click. not like a battery issue. .... But if Istart from the zero position on the starter it doesn't start on the first try ...
No horn / No lights when I lock my car - Hyundai Genesis ...
www.gencoupe.com/.../244433-no-horn-no-lights-when-i-lock-my-car.h...
Mar 30, 2014 - 16 posts - ‎8 authors
I do not know what could have caused this but when i lock my car... ... lock yourdoors with your key fob(might have to hit the lock button twice) ... The alarm/horn should start beeping. ... 2010 Hyundai Genesis Coupe 2.0T R-spec in Karussel White.... My lights flash when I lock it, but the horn doesn't sound.
2013 Hyundai Elantra Engine Won't Turnover, Won't Start ...
www.carcomplaints.com/.../Elantra/.../engine_wont_turnover_wont_start...
The 2013 Hyundai Elantra has 19 complaints for engine won't turnover, won't ...
Jan 04, 2016 | Hyundai Cars & Trucks
Why doesn't key fob lock/unlock doors?
Door Locking / Unlocking Problem - Kia Forum
www.kia-forums.com/kia.../68734-door-locking-unlocking-problem.ht...
May 9, 2011 - 10 posts - ‎4 authors Door Locking / Unlocking Intermittent Problem With Remote Keyfob ... being opendoesn't seem to prevent the car from locking, just the doors ... Power door lock issue
May 4, 2015
KIA Sorento 2013 car doors won't unlock while car is ...
Jan 20, 2013
Problem with key fob and unlocking the doors
Feb 16, 2011
Remote locking fob not working
Nov 13, 2010
More results from www.kia-forums.com
Nov 24, 2015 | 2013 Kia Soul
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
Apr 27, 2012 | Cars & Trucks
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Un work of the doors auto control lexus
4. Shut door.
5. Open door.
10. Close the door.
11. Open the door.
13. Close the door
Long beep to follow if successful.
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Hyundai 2009 Genesis 3.8 Logo
85 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Jerry Kramer
Jerry Kramer
tony wahlman
tony wahlman
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
