Question about Whirlpool AD35USS Dehumidifier
My dehumidifier keeps beeping when I turn it on and won't reset. Also cannot find filter.
During the night it suddenly started beeping and went to high and continuous run and could not be reset.I could not locate the filter to see if it needed cleaning
  • Ron Allain Dec 04, 2012
    Thanks for the help. I found my filter Cleaned it, vacumed the fan area
    I'll try again. I found my filter. Cleaned it, vacuumed fan and all, put it back together and lo and behold I was able to reset it and it works fine.Thank all
4 Suggested Answers
SOURCE: when i set the dehumidifier
I have the same issue... please post if you fixed it.
Thanks
Posted on Jan 18, 2011
  • 4736 Answers
SOURCE: whirlpool dehumidifier ad35dssi runs, but
Glad to hear that you thought to clean the filter, as that would have been one of my suggestions. Because, it's the most overlooked.
But, there is another one that equally overlooked and is probably the number cause of your humidifiers problem. The humidity extraction level is set to HIGH. Lower it to 32 - 35%. If your unit does not have an LED Screen readout, set the control on MINIMAL.
This is what gets confusing about the use of dehumidifiers. They work backwards from what most people think. The lower the setting, the more moisture/humidity is extracted from the house. The higher the setting/numbers, the more humidity remains in the house. The higher setting would be used only in the Winter, because removing all the moisture and humidity will make the house uncomfortable.
If this wet area, you mentioned is a basement. The ambient air temperature at floor level is colder than at chest level and dehumidifiers don't work well in temperatures between 40 & 60 degrees F.
If this is the case, placing the unit up off the floor on a sturdy table, counter, etc that can hold the weight of the unit, plus a full bucket of water will generally solve the problem.
Also, be sure that you're maintaining at least 12" of clear air space on all sides of the unit. If the air flow is obstructed, the unit will run all day and not extract any water.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 13, 2011
Testimonial: "Thanks! We'll give it a try. It's running very "quiet"too, and I see from my searches that it could be the condenser, etc, We'll See!"
  • 5 Answers
SOURCE: Hello, I have a Whirlpool dehumidifier
Hello Shane
Mine won't beep at all. But try this trick I watched the guy do when he came to service mine for the recall they had and push Humid button fan button and power button first hold the first two then push the power button and hold all three for awhile. What this did for him was verify all systems working all the lights came one in sequence.
I do this to mine and will beep twice and nothing else. I've taken mine apart to check the fuse and it's still good so there must be a component that is not working.
On the back of your unit you will find a 800 number which will get you in touch with Trans Global Service which serviced it for the recall.
George
Posted on Jul 17, 2011
Why does compressor continue running, even with dehumidifier turned off?
Hello Bernard, thank you for your post!
I see that you are experiencing an issue with the Frigidaire dehumidifier, FAD704DWD, compressor consistently being on. This could be a possible issue with your control panel or sensor. Since it could be any one of these underlying issues I would suggest contacting the manufacturer for further assistance. Hopefully this information is helpful to you. -Matt
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
Jun 02, 2011 | LG LHD459EL Dehumidifier
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Freezing problwm; very small amount of water was collected.
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Apr 27, 2011 | Soleus CFM-40 Dehumidifier
When I turn it on it continually beeps, and I cannot change the settings--it stays on "high" and "continuous run". Is there a way to reset this?
Try unplugging it for at least an hour. Over night would be better. By then, it should have lost any stored memory it has.
Feb 01, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Compressor no longer coming on (Newair AD-40A)
You can take out the switch and do a continuity test on the switch in the on poisiton. You can do this witha VOC meter. and and if the switch has a High resistence then you can assume the switch is the problem and replace that. If the switch works out, it would be wise to assume the compressor has shot out.
Thanks for using Fixya.com!
Aug 23, 2009 | NewAir AD-40A Dehumidifier
Hampton Bay Dehumidifier Model# HB50
MY dehumidifier leaks water from upper part of unit causing water to leak on floor while running.
Feb 23, 2009 | Dehumidifiers
Goldstar dehumidifier
Two possibilities:
1. Continuous running and there is water coming out of the unit to the floor drain; the unit is just doing its job. It is probably just that there is that much humidity in the room;
2. the sensors are faulty or were bypassed during the repair - the sensor would be testing the water coming out, if there is water, the unit continues to work, if none, then it shuts off. Most would also have an overfill float switch, again which could be bypassed, that likewise control whether the unit will continue to run or stop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 03, 2008 | Goldstar DH504EL Dehumidifier
Whirlpool AD35USS Dehumidifier Logo
470 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
