Question about Makita Drills
M802 Makita red drill. Anybody know where I can get some brushes for this old drill?
    Champion:
  • 304 Answers
Try www.oasistools.co.uk
Posted on Dec 17, 2012
SOURCE: makita 6222D hole drill bit is stuck
When this happened to me I held the shaft of the drill bit tightly with my hand and reversed the direction of drive for an instant. It released at that point. It still does that occassionally though.
Posted on Feb 22, 2008
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: How do you remove brushes from a makita cordless
you will need to GENTLY pry up on the brush shunt that you see and remove them. reinstall in the reverse order. they generally have a somewhat tight fit in the brush/motor tube
Posted on May 07, 2011
rowdy45176
  • 2176 Answers
SOURCE: hi have a makita bhp
take it back for warranty replacement, I would also take the charger to ensure it is not at fault.
Posted on Aug 03, 2011
Makita 6227dwe cordless drill can the brushes be replaced.
No, unfortunately this is brushes only come as part of the motor assembly Makita 6226DWE 3 8 Cordless Driver Drill Parts
Dec 24, 2016 | Makita Drills
Makita hr3851 won't hammer or drill
Try pulling out the brushes and blow some air in were the brushes go it may have gotten some trash in between the brush and the armature . they may need to be replaced, here is a pleace that will give you a breakdown and sell you the parts. http://www.ereplacementparts.com/makita-hr3851-rotary-hammer-parts-c-97_380_491.html
Jul 30, 2016 | Makita Drills
Why will my Makita drill not work when the battery is charged?
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Jul 06, 2014 | Makita 12 Volt Cordless Drill/Driver Kit
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
Jul 06, 2014 | Makita 6011DW Battery 1500mAh, 12V, Ni-Cd
MAKITA HMO870CUSER MANUAL
According to the manual, "The red service indicator lamp flickers up when thecarbon brushes are nearly worn out to indicate that the tool needs servicing. After approx. 8 hours of use, the motor will automatically be shut off."
Apr 24, 2014 | Makita Drills
Hi. I bought a Makita cordless drill, model 8391D. Whilst drilling a pilot masonry hole it suddenly stopped. The battery had only just started to slow so I changed it anyway to a fully charged one and the...
I would try changing the brushes and use compressed air I would blow out all the dust and lint I could from around motor.
If this does not help I would return for guarntee replacement. Thank you.
Mar 19, 2011 | Makita Garden
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Hi, My Makita DC18RA won't charge anything it just flashers the red and green light simultaneously it is not the batteries because I can charge them fine using anther charger. What is wrong with the...
none of these answers help. you cant return old chargers to the store, and the poster said his battery charged on a different charger. i have the same problem with 2 makita battery chargers and need to know if there is a part inside the charger that can be replaced.
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Grinding noise
possible burnt out in the brush holder assy,checked the motor
Apr 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
164 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
