Question about Samsung CLP 300 Laser Printer
Samsung clp 30 shadow printing
When printing text, pages display "shadow text" from previous pages. The actual text, from the current page, is printed, but text from previous pages remains lightly visable.
  • 3 Answers
SOURCE: SAMSUNG CLP 300N prints poorly after replacing toner cartridge
This is a fairly common problem, caused by a faulty black developer roller. I spoke to Samsung about mine, when it was 1 day out of the warranty and explained it started happening three weeks before (which was true). It had about 1,300 page count, when fuser kit should last 20,000. An engineer visited next day and replaced the roller, as well as a cautionary replacement of the paper pick-up rubber. Print is back working fine now. Chatting to engineer, the rollers have been modified now, so the fault must be causing concern. He said he's got another ten coming in stock tomorrow. Keep the previous toners, as they will still work once printer is fixed. I must say, Samsung support is excellent (the reason I bought from them!), so speak to them and so what they will do.
Posted on Feb 06, 2009
  • 220 Answers
SOURCE: Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
Posted on Jul 03, 2009
LuckyJackson
  • 72 Answers
SOURCE: rainbow line across the middle of the page
Possible print alignment issue.
Check the toner and then go to properties of printer.
Clean heads etc and then print test page.
Wizard should assist to troubleshoot
Posted on Jul 13, 2009
nakshatraipu
  • 241 Answers
SOURCE: I often get a red status light on Samsung clp-300.
You have to reset your printer. I think You have refilled the toner.
www.nakshatraworld.com
Posted on Dec 17, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Image of last print shows up on presant print
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Feb 11, 2014 | Samsung CLP-315W Laser Color Printer
When i print more than one pages. the 2nd page and later will always have shadow from previous page printout.
Drum Unit is not cleaning.
Either is not producing the right charge in the corona wires
your wiper blade is not functioning or the roller speed/ fuser speed is not correct
easiest solution clean drum with dry cloth
order maintence kit and replace rollers
next order new drum unit
order new fuser
Oct 28, 2013 | Samsung CLP 315 Laser Printer
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
Printing shadow from previous page
transfer belt damage please replace transfer belt or transfer belt wiper blade
Sep 28, 2011 | Samsung CLP-500, 550 Image Transfer Unit
How do I check my ink levels? clp-315
You can print a configuration page from the printer's control panel.
Use the configuration page to view the current settings, to help troubleshoot problems.
To print a configuration page: In ready mode, press and hold the Stop button on the control panel for 5 seconds.
A configuration page prints out.
Jul 21, 2011 | Samsung CLP 315 Laser Printer
Different looking text, but only in certain areas of the page.
Samsung CLP-300 color laser leaves 3-4 lines of various shades of black in middle of paper. Otherwise everything is great.
Posssible black toner cartridge problem?
Jan 30, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
