Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tuner replacement on RCA D52W20
I bought a 52" RCA D52W20(B) a while back. I paid next to nothing, but the coaxial input on the TV was broken off. If I look at it from the rear, I can see where it was supposed to be, and see a small bit of red on the other side of the hold. (Maybe a coil or something). Just through a little bit of research, I believe that that whole silver box itself is the tuner. Is there any way to replace only the F input, or do I need to replace the whole tuner?
I've already got the rear cover off, but If it is the tuner itself that needs replacing, I wouldn't know where to start. Any instructions/parts websites would be greatly appreciated. I don't have much tv repair experience, but lots of experience with computer/xbox/other electronic repairs.
Radio Shack sells an RCA composite Male to coax adapter
Female for a few bucks. Unsolder the composite connector from the tuner, replace, and resolder. Then screw on a Male to Male coax coupling. Done
Posted on Dec 20, 2009
  • 4 Answers
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Posted on Feb 22, 2009
  • RCA Master
  • 8,617 Answers
Go to this site they are RCA experts and have alot of parts that they sell cheaper than anywhere else around and they provide free tech support to help you do the repair. Just leave them a email indicating your model number and what the problem is. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 16, 2009
Broken tuner
If the board is not cracked,a qualified technician may be able to sloder another coaxial jack for a service call charge. Look carefully with a flash light........if you see the small board is cracked.....it will need the tuner and could cost $200. You may be able to cicuimvent by hooking your cable box or satellite box into the video inputs instead......select with input button on remote and should work fine with no repair at all
Jun 06, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The coaxle broke where you put the cable line on
The coaxial connects inside the set to the tuner. It needs to be resoldered in to the board & secured on the outside to the tuner. Its a quick fix at any tv repair shop. Unless u tried stick something inside & damaged internals of tuner
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable antena ready input repair
Purchase replacement at radio shack, disassemble the tuner, and solder the replacement in. It is not a screw in.
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV Cabel Connection
HD doesnt come over the coaxial cable into the TV. It has to use HDMI, composite (5 color RCA cables) or DVI. they can all be soldered back on if you ripped one out. easier to use another input if you have multiple formats back there.
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Coaxial to component
You may need an extra HD tuner for your TV. The only problem that you may have would be the original signal running through the coaxial cable. If it's just regular TV stations, the tuner should fix the problem.
May 22, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
RF Tuner
the tuner for this unit is a rca 264658 componet is nh101
Dec 10, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
933 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
