Loud noise comes from speakers when they are plugged into electrical socket
    Problem Solver:
  • 19 Answers
They are not suppose to be plugged into a wall socket, The regular speakers, They are suppose to be hooked up to the reciever,
Posted on Dec 03, 2012
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
My roland cube street starts making this really weird loud noise
Hi, Quick Check. Very often the input socket which is soldered directly to the circuit board, will have a broken solder joint. This is common on a very large amount of equipment. Try waggling the plug about and seeing if the noise comes and goes.
Easy fix, re-solder joint. Permanent fix, connect socket to board with flying leads, or fix socket to board with hot glue or epoxy resin.
All the best, Chris the Fader.
Mar 23, 2013 | Roland CUBE Street Amp Combo
Ysp-1100 clicks when power is pressed but does not turn on.
Sounds like a a pcb dry joint or a poor connection on a multiway plug / socket.
try removing and refitting all the pcb plugs - better still spray carefully with WD40
Goog luck, Gaz
Jun 21, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Noise coming from speaker with controls
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you havent used your speakers for a long time disconnect it and clean it with a cleaning solution.make sure the electrical contact(connection) is tight enough since loose connections will cause such sounds.hope your problem is tackled..have a nice day
May 22, 2009 | Logitech X-230 Computer Speakers
Very loud odd noise coming from radio speaker
There might be 2 probs
  1. The wires soldered to the the CD/FM input/output wires might have come loose leading to short/sparks causing the loud sound(constant).
  2. If there are any sockets requiring plug-in they may require cleaning with pure alcohol or rectified spirit(unlikely).
  3. The wire leads going to the speakers may be partially loose........................sodeep
May 11, 2009 | Car Audio & Video
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Jul 04, 2008 | Bose MediaMate Computer Speakers
181 people viewed this question
 Grubhead
Grubhead
