Question about Brandt WFH1276F Front Load Washer
Brandt washing machine won't start without 'help'
Hi I bought a Brandt WFH 1277F in France and for the past few months have had trouble getting it started. I don't get an error code, but in order to get it to work I have to 'Fonzie' the machine: open and close the door several times, turn the setting dial just a hair to the left and right, lift and drop the front of the machine. After a few minutes it will finally engage and run the full cycle with no issues. Unfortunately now it is taking longer and longer to get it working. Any thoughts on which part could be gone or how I could fix it? I'm not an electrician, but can do some basic work without blowing everything up. Thanks in advance for any help
SOURCE: my kleenmaid brandt 5kg washing machine has had a
hi dyan, are you based in australia? whome did you get to fix your machine? have you solved the issue now?
my mum has the same machine (which she loves) and hers has just stopped working and she was interested to know more about your post and issues you have experienced.
cheers
kelly
Posted on Apr 22, 2010
  • 190 Answers
SOURCE: how to operate the washing
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Posted on Nov 12, 2010
    jnchahn
    • 252 Answers
    SOURCE: my Brandt wahing machine does
    The only quick trouble shooting I can give you. Try unplugging the washer for fifteen minutes. If that doesn't do it then it is timer or motor.
    Posted on Apr 18, 2011
    • 6277 Answers
    SOURCE: I need user manual for
    You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
    You could also try the manufacturer's web site direct and there are often tabs on the Fixya site;-0)
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C.
    Posted on May 15, 2011
    SOURCE: Hi, My brandt washing machine suddenly have a
    Please help me my brandt wfd711a stop running and comes out error F02. any suggestions?
    Posted on Jan 09, 2012
    Brandt / mod wfh 1010k / type wa.380
    Do you need an Albanian One? No, look online with the model # and maker on google.com place owners manual after to enter
    Jan 16, 2014 | Washing Machines
    Washing machine wont spin
    Sounds like the belt either broke or jumped off the pulley. should be a simple fix from the back access.
    Feb 25, 2013 | Bosch Washing Machines
    Brandt WFK1458FE ERROR CODE F08
    go to http://www.brandt.com/ and get the support via ONLINE via chat or phone.
    God bless you
    Sep 25, 2012 | Washing Machines
    Cadliac deville 1995 need a throttle position sensor put in where is it located
    Having Check Light On & getting a code, doesn't
    mean your car needs anything
    It means you use the code to direct you to a place
    to start testing things.
    Parts only get replaced, when they fail a test
    You can throw some parts at it & get lucky a few times
    What I don't like about that, is you learn nothing from doing
    that.
    The TPS Sensor (throttle position sensor) pretty much tells
    you where it is. On the Throttle Body--- for the past 30 years,
    not a well kept secret!
    Jun 05, 2012 | Cars & Trucks
    My brother Se 400 which is only a few months old just started running really slow. When I disconnect the foot petal and do the manual botton "the arrow button" it still runs slow. I don't...
    have you checked to make sure the power cord is pushed in correctly?
    if the power cord isn't the problem then it may need to be checked by a service tech, because it's not suppose to be running slow just a few months after you bought it.
    I would call the people you bought it from & tell them what it's doing & see if they'll give you another one, I've been sewing for 30+ years & I wouldn't keep the machine.
    good luck
    Sep 22, 2011 | Brother Sewing Machines
    Hi - I have won a Brandt digital photo frame and radio in a raffle but unfortuantley, it has no instructions - can you help ?
    Sorry- not from the WASHING MACHINE forum ;-0(
    You will need to type into your search engine/web browser 'brandt digital photo frame' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
    You could also try the manufacturer's web site direct ;-0)
    John C.
    Aug 15, 2011 | Brandt Washing Machines
    '04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
    Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
    May 18, 2011 | 2005 Kymco Venox 250
    I need user manual for "BRANDT washing machine AA 1000RPM". Where I can find it? Thank you in advance!
    John C.
    May 15, 2011 | Brandt Washing Machines
    Brandt WFH1276F Front Load Washer Logo
    69 people viewed this question
    Top Brandt Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Harjeet Singh
    Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
