Question about Linksys Wireless-G WRT54G Router
I have a linskys wireless G access point. Its working for my laptop but just recently my laptop said that my interent secuirty is secuirty enabled and that linkys is a unsecure network. What do I do? It has never done this before.
  • jpconda Jan 11, 2009
    I went to the IP address for Lynksys and logged in using admin. (don't know if that was right) Then went to Wireless and added my SSID that I set up a long time ago...took out the SSID of lynksys...Clicked on reset security and totally lost the internet connection on my laptop. What did I do wrong?
    President:
  • 623 Answers
Jpconda - you did nothing wrong.
By changing your SSID, your connection broke, because you were still associated with your old SSID (linksys).
Right-click on your wireless network connection symbol in your taskbar and choose "View Available Wireless Networks". If you broadcast your SSID, you should see your new name in the list.
Just connect to it (and hopefully enter the security key..;-).
If you don't see it, go to 192.168.1.1 and enable the broadcast of your SSID ( on the Wireless Tab - Basic Wireless Settings). Don't forget to save your changes!
Once your are connected, you can disable the broadcast again, if you don't want someone else to "see" your network.
Posted on Jan 11, 2009
  • 340 Answers
I haven’t heard this before, but I wouldn’t be surprised if Bill Gates have found it in his hart to check your router to check your setup with the latest update to your operating system.
What you need to do, is to set some kind of security, on your router as well as on your laptop.
DO SET THE ADMIN password as the first thing you do, so that your neighbor can’t access your router.
Give your network a name (SSID) so that you can find yours if there is more around you. Network name are called SSID, short for service set identifier
Now, go to Wireless -> Wireless connection, to set the Encryption security settings.
Set security mode to WEP,
Set the Transmit key to your choice, if you know that you wireless card has 4 keys as well, I would use key 4.
Set WEP encryption to: 128 bit 26 hex digits.
Go down to key 4, and find combination of numbers and the letters a, b, c, d, e or f.
(ex. 414243444546474849404a4b4c) = 26 hex digits.
Save settings.
Now, before you leave, WRITE DOWN your SSID, your new password and key 4 with your settings, as you need to set your wireless card on your laptop with the same settings.
On WinXP:
Start -> settings -> network and right click your wireless connection and click properties.
At the top, choose Wireless network, find your network, (your SSID) choose properties and set these settings as you wrote down from the router.
Now, remove the cable and logon wireless…..
Regards
/Teis
  • Teis Thomsen
    Teis Thomsen Jan 11, 2009
    Plz let me know if you incounter any problems.
    /Teis
  • Teis Thomsen
    UPS, DIDN’T TELL YOU AT THE
    BEGINNING,
    - - - >>> USE A CABLE;
    DO NOT ATTEMT TO ACCESS THE ROUTER WIRELESS.
    /Teis
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
M50vc recover wireless
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Nov 30, 2012 | ASUS M50VC-AP012C Notebook
Can't find any networks
Are you near a wireless access point? You didn't give any info. Is the wireless adapter on? Enabled? Working properly? Is the wireless access point Working? Connected to a Provider? You see what I am getting at?
Nov 27, 2012 | Acer Aspire Computers & Internet
Im trying to hook up to linskys via my laptop and its asking me for the security key or pass phrase for linsky?
Hi Good day!! your linksys is password protected that's why its sending you a message to enter it's password, you need to enter the password of the router (linksys) if you want to access the router.. try this- username: admin password: (no password just leave it blank and then enter) that is the default password. hope it works for your linksys
Thank you for using FixYa
Please accept if my solution helps you
Nov 08, 2010 | Linksys Computers & Internet
Why link led of WAP54G Linksys is not blink if i install cable on LAN Notebook? i try reset this WAP but still not change. I can't login with IP 192.168.1.245. Thanks.
First RESET your router to defaults settings.Press RESET button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable then you can access it with default link http://192.168.1.1
or
http://192.168.0.1
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Then configure your router again set WAN settings as your interent service provider.
Enable DHCP if you want iip automatic from router.
CLcik on wireless and enable it .Configure your router as WEP or WAP then add code it is your password to connect internet.
Then save and restart router and computer.
Then connect internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 20, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I cant get my wireless connection to work
Wireless communication "takes two to tango". Your computer needs a wireless adapter, and you need a wireless access point to connect to. Most wireless access points are setup to be secure with a password, and to connect to a secure wireless network you will need that password, and possibly the type of encryption.
You should start by enabling the wireless adapter in your computer, and searching for nearby networks. Please tell me what operating system you have (Windows XP/Vista, Mac OS, Linux, etc).
Mar 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cannot Access My DWL-3200AP
If you can browse internet via same device
Start/ Run/ CMD/ type "ipconfig" (w/o ")
Use default gateway IP address as your AP ip address..
Enable java and use IE (some devices prefere IE)
e remember to score this tip.
Jan 15, 2009 | D-Link AirPremier DWL-3200AP 802.11g/b...
Connecting a laptop.
on connecting your laptop wirelessly, it is best if you set the router to have wireless security first.
accessing the router's setup page:
open IE, then type http://192.168.1.1 on your address bar, it will ask you for a username and password, thats both admin (these steps will depend if you have changed the settings on the router)
once opened, go to the wireless tab, change your Wireless Network Name (SSID) to something esle instead of Linskys, like your name perhaps. then set the channel to 11ghz and hit save settings.
now look for a Wireless Security SUBTAB, enable to wireless security, under security mode select WPA-Personal (PSK) set your algorithm to TKIP and make up a password on the blank space that says Passphrase / Pre Shared Key , that will be you wireless security code. now hit save settings.
in connecting your wireless laptop, make sure the wireless adapter on the device is enabled and it will automatically locate the wireless network and wil ask you for the security code, once you place it, you will get connection.
Aug 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Router problems
Did you enable the wireless on the router?
Jan 08, 2008 | Zyxel Prestige 334 Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
