Question about Maytag PYE3300 Dryer
Dryer belt broke on my dryer.
Our dryer has progressively not been drying our clothes. We have been having to have 2 or more full cycles just to get a normal size load of clothes dry. When putting in a load tonight, we hear a "pop" sound and noticed that our dryer was not turning. Upon investigation, we noticed that there was a broken belt. We don't know where to put on the new belt, and are wondering if this is the reason that maybe our clothes have not been getting dry. We have a Maytag Performance 7 cycle (model # PYE3360AYW) dryer that is only about 3 years old. Can you help please?
  • nyyfinsfan Jan 12, 2009
    Thank you for your detailed suggestions!! We will try it!
  • Maytag Master
  • 8,220 Answers
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
Posted on Jan 11, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
Sep 19, 2017 | LG DLG5988 Gas Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
Heats up hot go through cycle but won't dry clothes
If it heats up but clothes are not drying then it could be:
1- The vent gets clogged up.
2- The heater assembly consists of several filament, one of these is bad so it doesn't have full heat capacity. Therefore the heating element needs to be replaced.
Apr 27, 2010 | Estate TEDX640JQ Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
My Magic Chef dryer doesn't dry properly
remove the vent from the back of the machine, run it full of clothes from the washing machine and if it dries nicely, then you have a clogged vent that needs replacing.
Jun 16, 2009 | Magic Chef CYE2000 Electric Commercial...
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Whirlpool dryer
not element, same element runs Hi and low temp
whirlpool dryers have 2 thermostats,
40degreeC (low)100F
60degreeC (high)140F
the 60degree thermostat has failed
cost is between $15 and $40 depending on how the 'parts guy' feels on that day
the dryer is easy to open, check any of the 'change belt' questions or Joks instruction brief
Oct 26, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
331 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
