Question about Amana AOGD2750 Gas Double Oven
How do you light a gas oven
We turn on the gas and nothing happens
  • Anonymous Mar 12, 2009
    I have a Hotpoint stove/oven the stove burners work but the oven when turned on is emitting gas fumes. How can I reignite the pilot?
  • 306 Answers
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Posted on Jan 11, 2009
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Kenmore gas oven won't heat up
If your ignitor is coming on that means the oven control is supplying the power to the ignitor and gas valve. So the gas valve is ok because it is allowing for a complete circuit so what the heck is wrong? The ignitor MUST draw 3.5 amps in order to open the gas safety and allow the gas to come out. The ignitor must be very bright, if it is dim then it is bad. (MORE)
Posted on Feb 09, 2009
My oven will not light. When I turn the knob nothing happens. This is a GE gas cookstove, purchased in 1995.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 05, 2011 | Ovens
Turn on gas oven to correct heat nothing happenns
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 08, 2010 | Ovens
My oven won't turn on. the burners work, but when i turn on the oven, nothing happens, no gas smell or sound... no heat. the night i noticed it, i turned it to 450 and an hour later it was lukewarm, then...
Where the pilot light for the oven is located is a bulb that keeps the gas on. It is called a thermocouple. These get old and fail. They are easy to replace if you have some basic tools and mechanical ability. They are usually not too expensive-around $10-20.
Dec 20, 2009 | Ovens
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Jan 18, 2009 | Whirlpool SB160PEE Gas Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
May 01, 2008 | Blodgett 911-DOUBLE Gas Oven
Amana AOGD2750 Gas Double Oven Logo
838 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
