Question about Acer Aspire 3680 Laptop
Side screen brighter
My right screen is brighter than the left one please help... is it an inside problem? does it cost alot to fix?
    Scholar:
  • 156 Answers
There is couple of factors. Most probably that is a problem with your laptop's "CCFLbacklight" or "inverter board". googling with these two terms will let you know more about the problem. If its a CCFL problem then you need to change the whole LCD screen. A skilled tech can change the CCFL but touching the polarizing film will give you dark faded spots in the LCD screen. So it is a good idea to change the whole screen. Best option is to check it with a skilled technician. Hope this helps.
Posted on Dec 01, 2012
MY BLU STUDIO CELL PHONE SCREEN IS DARKER AND THE SCREEN JUMPS AT TIMES... WHAT CAN I DO TO MAKE THE SCREEN BRIGHTER?
Well on the main screen you can. You will see a circle with A inside anytime you touch that circle give you brighter or darker screen i hope that help
Aug 11, 2014 | Cell Phones
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF...
Sounds like a hardware failure inside your monitor.
If it's still under warranty I would suggest you return your monitor for a new one. If it's not, then I would recommend looking for a local repair shop to repair it or try to purchase a new or used monitor to replace it.
Mar 25, 2011 | ViewSonic VA1716w Monitor
I have Sony bravia XBR and right side the screen is more darker and have lost color. Any idea. please help if u can.
my guess is that the right side of the t-con board/LCD control unit if failing. this board controls video drive on screen 2 processors on the circuit 1 for right the other for left. if this does not fix then the problem is going to be the display it-self which is not cost effective to repair. Hope this helps some.
Also before replacing anything clean all ribbon cables between main board and lcd control unit and between the lcd control and panel.
can clean with pencil eraser. board location
main unit - circuit to the left or middle usually have inputs on it.
LCD control- top and center with 2-4 ribbons leaving the top and going to the screen.
hope this helps.
Apr 27, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Sep 22, 2009 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Installed new tail lights because one had burned out, but when braking right tail lights get brighter and left side goes dark
the bulb on the right is a double contact bulb, same has on side is blown, please replace the bulb.
Jul 30, 2009 | 1996 Cadillac DeVille
Euro low beam right side brighter than left side
You have a bad ground on the left low beam. Using a test light connected to ground see what wire is positive with low beams on. Using a piece of electrical wire connect one end to ground and with the headlight connector connected to the headlight and headlights on stick the other end into back of the connector at the ground wire. If the light gets brighter, you can cut the original ground wire to the connector ( 2-3 inches from headlight connector) and run a new wire from ground and connect it to the wire at the connector. Hope this is helpful.
Jun 21, 2009 | 1994 Honda Civic
Black screen on the right side of my acer 5630
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
Nov 25, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 3680 Laptop Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
