Toshiba 500 GB external drive error
Hello, I have a problem with my toshiba drive. I bought it from Germany before three months. It worked ok, but now when I plug it in it makes a sound like a tik every second for 30 seconds then it stops for 1 minute and then again for about 20 seconds the tik noise. After that it don't appears in the auto play. When I go to device manager there is a yellow sign with an ! in it. it has the name usb mass storage device. I don't know what to do I have about 200 GB storage on it and it is very important to me. So if anyone knows what should I do please write me! Thanks for reading!
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll through all of your devices
or for Windows 7 click start right click on computer select properties in the left pane device manager scroll through all of your devices.
If you see a yellow question / exclamation mark ? ! or a Red X you will need to update the drivers for this device right click select update driver/reinstall driver software.
If you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
or you might have to download them
Rather doing a driver hunt which can take hours.
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
This might take some time being a freeware driver solution
Note: The Driver program will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
The ticking noise might be a dirty hard drive with the reader arm skipping across the platters of the hard drive.
You could give it a firm tap on the top of the hard drive to free the reader arm also run the chkdsk utility on it.
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
Hope this helps
Posted on Dec 01, 2012
  • 1 more comment
  • Jovan Gjurchinoski Dec 05, 2012
    http://www.youtube.com/watch?v=MYdQLrQmu... Here is a video of my HDD. The problem is that there is a scratch like a circle around the disk. It is in about 0,5 cm from the center. Please if you know what can I do, I have very important files on the HDD :/
  • Brian Sullivan
    Brian Sullivan Dec 05, 2012
    you might be able to recover your data you will need to buy some hardwarehttp://www.ebay.com.au/itm/120738767650?... USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb porthttp://www.bing.com/images/search?q=SATA... Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive or get one of thesehttp://www.ebay.com.au/itm/NEW-2-5-SATA-... the hard drive might be dirty with the reader ard skipping across the platters of the hard dreive give it a firm tap to one side to try to free up the readerarm i have used these usb devices to recover lots of data from damaged hard drives it works if you need more help or if i have missed something post a reply oh yes you will need an Ebay account to buy these or you might find something closer
    I will send you pictures how the port to the HDD is, I think it will not fit with those cables. I hope that it will! In a few minutes I will send pictures! Thanks a lot for this information!
SOURCE: SimpleTech 320 gb. Code 10 Problem
no me abre simpletech mi correo rufoteama@hotmail.com
Posted on Oct 17, 2008
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
mail2pvs
  • 390 Answers
SOURCE: External hard drive shown as portable disk and does not work
hi
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
cheers
pls rate if this was any help
Posted on Jul 13, 2009
SOURCE: Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Posted on Oct 04, 2009
lserni
  • 466 Answers
SOURCE: I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Posted on Nov 02, 2009
No power signal in my external hard drive
Can you still read data from HD? Test USB port with an another cable and an another HD or some USB equipment you know are OK,
Mar 24, 2014 | Toshiba Canvio 500 GB USB 20 Portable...
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
My lenovo z61m computer is going to sleep every three minutes when the above message appears. this problem started when I started using a 500 GB toshiba external hard drive
disconnect the external drive and see if it still happens. If it does, the timing may be coincidence...check the main hard disk for bad sectors.
If this solves the problem, have the external drive checked for bad sectors.
Also with the external drive disconnected, open up a command prompt (or go START, RUN) and type sfc /scannow
this will check the system files for errors and replace any corrupted ones.
NOTE: you will need you OS CD when you go to do this.
Feb 22, 2011 | Computers & Internet
I have a three month old Toshiba 1TB external HD. buy now it decided not to allow me access and asks me to Formatt the Drive. I do not want to lose my data......!!! What do I do
had one do that,,,try plugging in another usb slot c if it does it,,,also reboot with it pluged in ,,c if that helps,,if not go online to toshiba site,,may be others with that prob,,k
Oct 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Toshiba 1tb external HDD that works fine on TV not on PC anymore
Try using it on another computer. If it doesn't work the drive may be bad.
Mar 14, 2010 | Western Digital My Book Essential Edition...
Reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
Apr 08, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
