Question about Keurig B70 Coffee Maker
Lights blinking on kergu but want brew
Water tank is full but blinking only small cup lights up and can hear it run still saying heating water but never coffee
  • 1,511 Answers
Plugged upper tube to heat section. Clean Pg. 19 Manual
Posted on Feb 06, 2014
SOURCE: Delivers only small amount of coffee per brewed cup
this is not a scale issue, mine arrived from the factory producing only 6oz of water. way to strong for most. called the factory, scale, scale blah blah blah, vinegar untill we were blue. bored one day took the unit apart. on the right hand side there is some clear tubing which housed a one way valve, took apart and the valve was partally clogged. removed cleaned and reinstalled, this valve works best when not fully" seated" where it belongs so reinstall gently into the hose and leave it alone. I know what your thinking scale, scale scale. wrong. still only made 6 oz cups. there is a timer device on the back wall of the front panel on the right side as you face the unit. it is adhered to the wall with two sided tape. pry it off and on the back low and behold is a timer screw that changes the length of pump run time. turn clockwise with a sharp knife or eyeglass screwdriver and retest. 9oz of water. shame on keurig for not being more responsive to its customers.
Posted on Jan 19, 2009
SOURCE: One cup brewer, says it is brewing, but the
If the brewer heats the water but it doen not dispense this is probably because air is trapped in the tubing of the water system.
To solve, use as air compresser with minimum pressure (20-25 psi) and force air through the system using an air nozzle that is long enough to reach into the hole into the area where you fill the water. Place your hand under the dispenser and ensure you can feel the air from the compressor coming through.
Once you clean out the lines, you should be good to go.
We have had our coffee maker sitting on our shelf "broken" for months now. We tried this last ditch effort before tossing the machine in the trash and low and behold it worked! :)
Posted on Apr 05, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: does not brew coffee consistencty,
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
heatman101
  • 43501 Answers
SOURCE: my Keurig will not brew a full cup. half the water
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Feb 26, 2011
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Will not brew coofee, light flashes but does not put water through
Check if the water is coming back out through the overflow into the tank. If hot water is running into the tank, it means the output is clogged. Run something small up the water output in the top part of the brew head and swirl it around to break up any deposits there. Then run a cup without a k-cup to flush out the debris. A friend of mine actually used a small straw and sucked out the clog - but I wouldn't recommend that!!
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
I set the brew size on the Keurig, but can't figure out how to get the lights to stop blinking and make the coffeemaker actually brew me a cup of coffee. I've held down the brew button, thinking that would...
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
Dec 18, 2010 | Keurig B70 Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
How I heat the cups in the heating plate?
You can just run some hot water from the machine into the cup to heat it up, just before using, as for the water tank it is always a good idea to have a full tank so that the machine can replenish the boiler if needed.
May 12, 2009 | Breville ESP8XL Espresso Machine
Keurig B70 Coffee Maker Logo
102 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
