Question about Dell Computers & Internet
Dell dimension 5150 sound is breaking up
Sounds raspy as if people talking or singing have a bad cold
    Problem Solver:
  • 16 Answers
If problems exist only in certain programs check software setting for audio. If problem is system wide, go to control panel, sound, check to see which inputs and outputs and set for default and if those are the ones you want. Open up your mixer and check those settings. If you're using some real audio intensive application - meaning those that require alot of data processing - you may want to upgrade your sound card to one compatible with aiso drivers.
Posted on Dec 18, 2012
crash748
  • 10 Answers
SOURCE: I have a dell dimension 5150 desktop problem; turn off after 60 minutes working.
Hi, maybe he was over heating, open your tower and look the fan of your CPU and POWER SUPPLY. Did they work? If yes, did the dirt on the heatsink of the cpu hide the heatsink? If yes clean it and make a test!
Posted on Oct 29, 2008
SOURCE: dell dimension 5150 won't start
See solution in http://www.fixya.com/support/t1372311-start_up_fault
Posted on Dec 31, 2008
  • 2692 Answers
SOURCE: fan/ engine whining sound
If the fan is only making wind noise it is ok. If it is making matalic noise replace fan. It would be a good idea to clean (blow)out the dust and dirt for the inside of the computer at this time.
Posted on Jan 12, 2009
ap-it
  • 53 Answers
SOURCE: Flashing orange light on power button of Dell
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Posted on Aug 04, 2009
SOURCE: Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Posted on Sep 01, 2009
We understand that your problem is: dell dimension 5150. A few seconds after powering up, monitor display goes blank. PC and monitor is powered up. If I press escape after a while, I can momentarily see...
This sounds to me like your monitor has gone bad. Often times this is caused by the internal components (capacitors usually) going bad, or the back light burning out. Sometimes this can be repaired by replacing the bad capacitors or light, however it is usually more time and cost effective to find an inexpensive replacement monitor. I myself have had good experience with the service at www.compusa.com as well as things being reasonably priced. Hope this helps.
Ray
Apr 11, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Cannot get any sound
Make sure your speakers are pluged in the green socket at the rear of your computer case.
Secondly, use the driver disk for your PC to install the Sound drivers, if you do not have them, serch for them on google. Download them and install. Either use Dell Dimension 5150 audio drivers in your search or the exact model of your mainboard.
Please take the time to rate my expertise.
Thanks
Oct 31, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
FLASHING LIGHT ON THE PC AT THE POWER ON BUTTON---SYSTEM WILL NOT POWER UP
Sounds like Faulty RAM modules, Open the box, and Try removing the Memory and re-inserting it, if that does not work, try one at a time and start the machine..**Make sure u close the Box before powering on. It could be bad Memory (RAM) module.
see link to see how to open and check the memory modules:
http://qwickstep.com/search/view-answer/how-to-open-dell-dimension-5150.html
See here for complete list of Beep Codes:
http://support.ap.dell.com/support/edocs/systems/pmac2cm/en/en_ug/error.htm#system_flash_codes
Sep 04, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Where is the microphone on a dell dimension 5150?
You have to buy an external mic and put it in the sound card - the machine doesn't come with a mic installed on the unit. Some lap tops do but desk tops do not.
Apr 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Where to plug in microphone on dell dimension 5150 pc
Look on the back of the unit for a Pink connector.
The sound card usually has the Speakers, inline and Microphone color coded. Some Dell units have a microphone and speaker connection located in the front. Door swings up or out to reveal extra USB plugs and these connectors.
Hope this helps!
Nov 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 no sound - please help
You should be able to download the original driver files from Dell Support Drivers & Downloads.
However, this may be worth a try:
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click
and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service
status," start is selected.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 won't start
Dec 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can someone olease help me?
it sounds like your os in corrupt. re installing windows should help you out.
Oct 19, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
