Question about Electrical Supplies
Kohler 22ry generator won't run
Engine startup and stop
4 Suggested Answers
  • 905 Answers
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Posted on Jun 12, 2010
ROMOAS
  • 97 Answers
SOURCE: I have an 18kw kohler
change the temp sensor and re test the gen set these have a bord that senses if theirs a issue with the engine and will cut the bower to the get head so theirs no load on some mod's then when the temp reaches a higher point they shut down. re-post is this does not fix the issue i will review the books on the unit.
hope this helps
Posted on Sep 01, 2010
stewbison
  • 577 Answers
SOURCE: I have a 5500 ppg
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Posted on Sep 29, 2011
Kohler 20 resa generator lopes when running
engines that dont run smooth are most allways a problem with fuel , clean/replace all parts in fuel pathway , including the carb
May 20, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
My lawn tractor makes a knocking noise when starting
It sounds like a valve rod, or you can have damaged a con rod.
Apr 30, 2013 | Kohler 22HP Replacement Engine SV620-3202
Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
Jan 25, 2013 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Kohler 14 RES won't start
You need a couple of things / options. The carb heater base, and an oil heater (srews in the drain hole, and possibly a battery blanket at that temp. Some OEM's offer an adhesive strip that you can also stick to the bottom of the alternator, that is also 120V and warms the generator windings to keep moisture out
Not sure what country you ar ein but in the USA/CA they will be a 120V accessory and as such need utility power at the generator
Dec 31, 2012 | Kohler 14RES 14 Kw Generator
Kohler Generator won't start
If you have a drip leg near generator open that up for a sec and then try it again.
Nov 16, 2012 | Kohler Electrical Supplies
Kohler Generator has a noEc error code
My 11 month old Kohler 14RESL stopped working sometime this month. The GFI outlet to the trickle battery charger tripped and the battery charger went dead and so did the battery. When I realized the GFI had tripped, I reset it and the trickle battery charger started recharging the battery overnight. In the morning I tried to start the generator by pushing the run button - nothing happened except a message 'noEc' appeared on the status screen. I called Kohler and was referred to their local distributors. After a whole day of phone calls to many distributors, I finally found one, Kraft Power, who would come out on an overtime basis and fix the problem. I chose Kraft Power because they were the only company who knew what 'noEc' meant. They told me that since the generator had lost all power (no trickle battery charger), the engine had lost it's configuration! I have worked in the technical field for 25 years (computers, networks and remote diagnosis) so this answer was particularly troubling. THIS SHOULD NOT HAPPEN. The technician had to connect to the port on the controller, bring up Site Tech on his laptop, and enter two pieces of of information into the configuration. 1) 14RESL and 2) the engine type. We had to use a mirror to read the engine type as it was under the oil filter!
Sep 17, 2012 | Kohler 12 kW Emergency Power System -...
White smoke pours out of exhaust on my SV730 Kohler engine when I start it. Then it stops and the engine runs good. I think it is a bad valve guide or a valve isn't seated right and oil is running
If you filled it up with oil yourself, then you might have put in too much, Ive done that a few times myself,, try ansd drain a little, about two to three ounces, then try to start it, make sure to do this when its cold.
May 07, 2012 | Kohler 25HP Replacement Engine SV730-3001
May 26, 2010 | Kohler Electrical Supplies
Electrical Supplies Logo
85 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
