Question about Lexmark E238 Laser Printer
Lexmark E238 paper jam
Paper jams inside the printer. It clears the tray and approx 2" out of the fuser in back. It happens on every page I try to print
  • Louis Stanly
    Louis Stanly May 11, 2010
    Does the test page have same kind of issue?
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
How to fix brother printer paper jam error
Follow the steps below to clear the paper jam.
  1. Pull the paper tray completely out of the printer.
  2. Pull the jammed paper up and out of the printer.
  3. Press the cover release button and then open the front cover.
  4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. To prevent damage to the printer caused by static electricity, DO NOT touch the electrodes shown below.
  5. Open the back output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7. After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  7. Close the jam clear cover. Close the back output tray.
  8. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
  9. Put the drum unit assembly back in the printer.
  10. Put the paper tray in the printer.
  11. Close the front cover.
http://support.brother.com/g/b/faqend.aspx?c=hk&lang=en&prod=hl5040_all&faqid=faq00000026_010
Sep 11, 2017 | Brother Office Equipment & Supplies
I have a lexmark e238. Keeps showing paper jam light after cleaning rollers even though no paper is in there.
Either paper is moving too slow through the paper path or one of your paper path sensors is not registering. Pull the paper tray out and check to make sure the little plastic sensor is swinging free. That sensor tells when the tray is empty. Follow the paper path thru the printer checking all the sensors to make sure they are "opening" and "closing".
Apr 07, 2015 | Lexmark E238 Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Dec 21, 2010 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I have a paper jam in my E240 Lesmark printer.. A sheet of paper is stuck on its way to being fed out of the printer, at its top and back. On the front, the sign indicating that more paper is needed is lit...
Here's an article on How to Clear Paper Jams on a Lexmark E238, E240, E240n, E340, E342n Printer. Just click on this link: http://bit.ly/cBXKAL. This might give you an idea on what to do when having a paper jam problem on the printer. If you need further assistance, don't hesitate to contact Lexmark technical support or call your authorized service provider.
Aug 27, 2010 | Lexmark C533DN InkJet Printer
Lexmark e238 jams every time i print prints about 2/3rds page
lex is junk ...stay away from this brand ..try others but i recomend epson.good luck
Sep 13, 2009 | Lexmark E238 Laser Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark E238 Laser Printer Logo
407 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
