Question about Garden
Need help setting the dip switches on a balboa base model vs500z
2 Suggested Answers
SOURCE: What is the difference between
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Posted on Sep 09, 2011
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Balboa control board wiring for 2 pumps, no circulation pump though
I believe you are barking up the wrong tree.
If I understand you correctly, the pumps are backwards!!!
Pump #1 is always a 2 speed pump.
Pump #2 is usually just a 1 speed pump.
When the filtration cycle comes on, "Low" speed is supposed to be the speed that does the heating.
But when your pump is on high speed, the movement of water is creating friction and that will heat the water and provide you all of the error codes you have been experiencing.
A 2 speed pump is normally a "Circulation" pump.
as far as dip switch settings, there is a key on the label on the inside of the load box cover. It will be in a little table.
Dec 26, 2012 | Balboa Instruments Garden
What is the difference between a Balboa VS500Z and a VS501Z
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
Upper control panel flickers and will not allow me to control temo
how old is spa?
if new then circuit board maybe set on a mode setting that is used when being tested in the factory, locate dipswitch block on circuit board and move dip switch for MODE, should have a layout of dip switches on reverse of lid to control box
if older then you may need a new control panel (top side)
Adam Miller, Canadian Spa Company, UK
Aug 06, 2010 | Balboa Instruments Duplex Digital Panel 2...
I have been unable to switch operating mode of Balboa spa controller VS500Z from 110 volts to 220. I have 220v appearing at the neutral in that has nothing connected to it. Dealer gives up. Balboa does not...
I had to wire mine the same - found this on their website - check the bottom left corner - you should be all set. Good luck!
http://service.balboa-instruments.com/appnotes/VS5xx_Config_Guide.pdf
Apr 13, 2009 | Home
Door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Nov 22, 2008 | Home Security
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
