Question about Sharp MX-3501N All-In-One Printer
Can i connect a sharp mx-3501n to a wireless network using a wireless usb adapter
3 Suggested Answers
  • 120 Answers
SOURCE: How do i print a big envelope in a Sharp MX 3501N
Select the heaviest paper setting available and only use the right-side manual feed tray.
Posted on Feb 24, 2011
  • 120 Answers
SOURCE: how to clear error code
If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Macbook can't connect wirelessly to sharp 3501n copier
I think you don't have the right driver for connecting it. Check it with other comp once or cellphone.
Engine Performance Chip
Aug 08, 2012 | Sharp MX-3501N All-In-One Printer
How to install printer driver when its connected to network
connect your printer to switch or LAN area of router then go to computer to install printer driver CD just insert to cd-rom automatic install . read instruction step by step.
May 27, 2011 | Sharp MX-3501N All-In-One Printer
How do i print a big envelope in a Sharp MX 3501N printer? Which option should i select?
Jan 17, 2011 | Sharp MX-3501N All-In-One Printer
How to setup SHARP MX 3500N, to use it for printing wirelessly.
Buy a wireless print server. Which ever company you buy from will have a help line and guide you through set-up. They are priced $60 to $100
Aug 13, 2010 | Sharp MX-3501N All-In-One Printer
I am connected to the sharp mx-3501n via a network and i have been printing in color for some time now, however, recently it only allows me to print in black and white while other people on the network are...
In the properties menu of the printer. Click on the tab of job handling. Make sure your user information and password for the copier has been entered. Without this you can only print black and white.
Jul 28, 2010 | Sharp MX-3501N All-In-One Printer
HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
just4fixya@gmail.com
Feb 27, 2010 | Sharp MX-3501N All-In-One Printer
How to connect a sharp printer mx3501N to a network
the best way is to hook up the copier to the closet router set the machine to dhcp let it assign a ip address and install drivers, etc...
Nov 04, 2009 | Sharp MX-3501N All-In-One Printer
Sharp MX-3501N All-In-One Printer Logo
122 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
