Question about Epson Stylus 2200 InkJet Photo Printer
Glossy paper option not showing
My epson stylus photo 2200 is not giving the option to choose glossy paper under drop down menu. I just loaded the latest driver but still not working.
  • Anonymous Mar 26, 2009
    kcdart210 - I assume that's for Windows - there is no setting I can find OS X to set photo vs. matte black.
  • metafizx Apr 24, 2009
    kdcart's answer helped, the ink cartridge must have been replaced with the wrong one. it says "matte black T0348" in the printer settings, will find out if the photo black cart fixes the problem.
    thx
NO do not reinstall driver!!! the solution is much simpler!
go to print>page set up> maintenance tab> printer & option info tab> make sure photo black is selected NOT matte black which is just for matte and watercolor paper. I can't find the
that should do it now I've got to get help wit my problem, banding with the 2200...
Posted on Jan 13, 2009
I had created page of 10 X 3 inches in Epson LQ1150 by using server properties. Page got created. But not showing when we want to select that page created one.
Posted on Jun 12, 2009
    Genius:
  • 1,447 Answers
Hi
What operating system are you using? try selecting the paper size and then paper type on printer driver and make sure its the default printer, if all fails. uninstall and reinstall driver.
Posted on Jan 11, 2009
How do I print using glossy photo paper?
select the paper type in the printing preferences section. Make sure the glossy side is down when you load the paper so that it prints the correct side.
Oct 06, 2011 | Epson Stylus CX4800 All-In-One InkJet...
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson stylus k3 r2400
Hi Lisa
The R2400 has the choice of two black inks, MK and PK. One is for Matt printing, the other (called photo black) is for gloss.
If the printer has the matt cartridge fitted it only allows suitable options, including paper choice, to be selected. If you change the black cartridge from the MK to the PK one, you should then have the choice of gloss paper.
Rich
Oct 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Printing paper choices
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Aug 19, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus 2200 InkJet Photo Printer Logo
232 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
