Question about Dell W4200 42 in. HD-Ready Plasma Television
I have a dell w4200hd. The picture started showing small signs of "snow" lines showing up. A week or so later it ran thru the entire screen and looked like an old analog tv where the signal wasn't
Dell W4200HD. Bought march 2005.
  • Tina B. Dec 01, 2012
    The inputs are okay. The snow shows up on all other inputs. Eg. DVD player or DVR hook ups are also scrambling.
    Master:
  • 879 Answers
It sounds that the input connections to the set is poor. Check all the connections for tightness.
Posted on Dec 01, 2012
4 Suggested Answers
  • 3940 Answers
SOURCE: Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Posted on Jun 13, 2008
jdvillanueva
  • 2098 Answers
SOURCE: popping/static sound coming out of
Hi hodges_ed,
This symptoms indicated of internal problem in the unit itself if the static sound is present in all inputs.
The is caused by the following reasons :
> Faulty power supply - once there an out-of-regulation condition on the power supply feeding the audio circuitry, static sound will produced to the speakers. This is commonly caused of leaky/dried filter capacitor. Leaky capacitor has a physical indication of fault like bulged/dome at the top or in the bottom and can easily identified. Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition.
> Faulty audio circuitry - Once the sound IC has a faulty internal circuitry, same symptom will produced. This is considered partially faulty and needs replacement. Another reasons is the faulty coupling/bias electrolytic capacitor in this section.
This kind of symptom is not DIY and I would advice you to look for a qualified technician to troubleshoot the problem.
Hope I help you.
Have a nice day!
Thanks for using Fixya.
Posted on May 18, 2011
  • 517 Answers
SOURCE: Dell W4200HD - While watching
Good day!
may I know if your TV have a sounds even humming?
Posted on Jun 06, 2011
Dell w4200hd
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 27, 2013 | Televison & Video
Had LG6700 8 weeks today a faded line ran down centre of screen 15 cms wide now screen won't show picture or turn on?
you can only replace lcd's not fix them, take the item back for a manufactures warranty replacement- it sounds like the lcd pixels dead or at least on its way, also a possibility the lcd controller is malfunctioning
Mar 30, 2013 | Televison & Video
2008 Chevy Equinox would not start, turn key and nothing happened, replaced battery, ran just fine for a week. Tried to start one week later it acted like it wanted to start but wouldn't. Had ju
Usually a sign of something draining the battery.
The machine test probably showed the battery could hold a charge and the alternator was charging the battery.
You may need to have someone check for a power drain.
When the key switch is off, there may be a weak short to ground or a relay or component that is using power.
Jan 22, 2013 | 2008 Chevrolet Equinox
I have a vizio 46 in lcd model # VW46L FHDTV10A and it started with the whole left side going dark and then it would get better after an hour or two. then about a week later the entire left side of the...
I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
This could also be the CCFL bulbs that are aging and need replacement. Those are around $20 each for a bulb
Hope this helps! Please rate :)
Mar 14, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
Dell Latitude D620 Nvidia Quadro NVS 100m
Suspected it's a graphic error. Try re-installing your video driver to it's later version.
May 30, 2009 | Dell Latitude D620 Notebook
Jun 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Lines coming down from the top of screen
Those lines are beaming in from the planet Alenod. For the moment you'll only be annoyed by those lines. But when those lines finally expand the entire surface of your screen you and everything in your viewing area will vaporize. Gosh, If I were you I'd chunk it as quickly as possible and buy a 47" Vizio! They're on sell at Sams! Pleeze hurry!!
Mar 05, 2008 | Televison & Video
Polaroid FLM-3232
Unfortunately, LCD panel has cause of the problem and it's not worth to fix.
Sep 16, 2007 | Polaroid FLM-3232 Television
Dell W4200 42 in. HD-Ready Plasma Television Logo
88 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
