Question about Fuji FinePix S1000FD Digital Camera
About seven days ago bought shelf display Fujifilm S1000. Worked fine at the store. Got home, read instructions, powered up, lens would not extend, "zoom error" displayed. Camera was room temp. When switched on, camera beeps, extend motor clicks, sounds like a gear engages for a split second. Took back to store next evening, it worked fine. Next try at home, same problem. Back to store, worked fine. Tried at home and at work, still "zoom error". Again to store, worked fine. Ready to return, still puzzled as to operation at store, elsewhere not. Same batteries, ok.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Mtx surround sound sub is on but no sound or thump.
most electronics now days only last for about five to seven years
so I would get checked out by a technician.
Jan 27, 2014 | MTX Audio Players & Recorders
I bought a FujiFilm FinePix S1600 one month ago. I used it for couple of times and was working fine. Then suddenly I couldn't switch it on. When I press the power on just flashes and it is not switched on....
The sounds like a systems control board problem, or the systems control has detected an issue with the camera. The only option is to return it to the place of purchase for repair or exchange.
Jan 18, 2011 | Cameras
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Panasonic SA-AK330
Change the spin motor disc
Jun 08, 2007 | Panasonic SC-AK330 Shelf System
Reading CD message
You can use a CD Cleaner as a first step, if it didn?t work the problem need an expert technician to clean the lens or replace it. Good Luck Toufic Malek
Jun 04, 2007 | Sony CMT-HPX9 CD Shelf System
Fuji FinePix S1000FD Digital Camera Logo
160 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
